Muller Dynamo
0 Members and 63 Guests are viewing this topic.
scratchrobot
Quote from: redrichie on June 13, 2011, 03:14:59 PM
@teslaset,
I agree.  Seems to me the last bunch of pages has a ton of great info.  and a lot of it I will use.  But extra caps that are nowhere to be seen in the videos or commented on  in the forum, though excellent, are a horse of different color .  Like I said tons of great info.  But as far as I can tell even in the pre release and the post release videos there are not 2 caps, or a whole bunch of mysterious theoretical components yet the speed up under load is happening.  I know so many of us are chomping at the bit to explain the unexplainable here.  There will be time for ya'lls Nobels later.  First lets make some machines spin.  then spin faster under load.
   MY rotor design was a total failure.  I believe that I had magnets way to close together.  So back to square one.  If anyone has a suggestion as to how far to space 1x.75 in neo cylinders please speak up.  I will tell you that one magnet spacing is waaaaaaaay to close.  there is virtually no scalar south between the magnets.  I couldnt even get a Bedini circuit to trigger at all.
I also agree, lots of great info on the last pages and I don't think Romero used caps but maybe he matched his coils with the windings and magnets?
Again look at the Kromrey converter, only coils and magnets, works also without rectifier so no extra parts.
bolt
Capacitors are not compulsory if the coils are wound and matched in such a way as to produce the desired effect! However chances are you do not know without winding literally hundreds of coils which create the best conditions as Romero discovered. Since the introduction of caps to tune the coils we have about the ONLY other replication that has shown zero lugging when the load is applied. (albeit a small o/p)
Take it or leave it and be  frustrated you have built an expensive pulse motor  toy :)
PS go look at about day 3 of this thread. I knew back then what was required and i said i don't expect more than 1 or maybe 2 people out of 100 replications to get it work.
scratchrobot
Quote from: bolt on June 13, 2011, 03:59:42 PM
I already build an expensive pulse motor toy and thanks to you guys I'm ready to play with it :)
teslaalset
We will get there.
The only thing we need to do is not to get distracted, stick to the concept and have patience and determination.
Remember Romero did not do this overnight.
dutchy1966
Quote from: teslaalset on June 13, 2011, 04:25:14 PM
We will get there.
Correct! Mechanically the first replications are (nearly) ready. Testing can now begin and the proposed advanced concepts can also be tested soon.
My feeling is that this thread has more merit than any other in the last couple of years....
