Muller Dynamo
0 Members and 66 Guests are viewing this topic.
poynt99
Good one scratchrobot.
That's both interesting and encouraging. ;)
.99
neptune
@K4ZEP . Hats off to you my man . How can the "magic" remain hidden with guys of your calibre on its trail ?
@ Bolt . According to the findings by K4zep , you may have a better understanding of this thing than I previously thought . Remember that not all of us have the depth of understanding that you have . And not a few of us are old dogs trying to learn new tricks . What at first appeared to be a very simple machine , has a lot going on that I never imagined . Romero said he doubted that many would understand it . My biggest hope is that the Priciples behind it will be understood , and that ever simpler machines can be made OU , eventually leading to solid state .
Tudi
@K4ZEP: that scope shot is exactly how it should look like if you ever get to tap ZPE. An AC voltage that increses in amplitude over time.
In theory there is a friendly practical advice. When you get the system to start converting back the energy just reset system state when you started to get the increasing effect.
It is quite complicated to maintain the state to get the increasing efect over long period, at some point you will probably loose the effect due to one of the parameters changing.
bolt
Quote from: neptune on June 19, 2011, 10:51:32 AM
Thanks but im still learning every day even though i have a handle a few things.  But can you imagine what i could achieve if i was properly financed to take the theory to the bench???  We could have been where we are now 3 or 4 years ago.
I have a VERY good theory on the TPU and kapanadze systems but i doubt i will ever get chance to try before someone else replicates it, puts up youtube vids, makes it appear to be easy then no one else succeeds because the understanding and tuning aspects are missing.  Going thru a 1000 dollars worth of components  a month is dead easy in this game. This is peanuts to many people but funding people like me is a dream bigger than finding OU itself. To me that is the EASY part.
Just in case you think im lazy i do what i can and have been working on HHO the last 6 months but it has to be done VERY slowly when i can afford to add something to it.
https://sites.google.com/site/silverfreeenergy/home
konehead
Hi silver
thanks for the constant hammering my skull is starting to crack now...
Heres my nuts and bolts version now:
In the Romero rig, the coils FACING one another are strung in series, but "cancelling series" (which is something you wouldnt want to do to to make power normally so usually everyone passes right over this method)
Now you go ahead and short coils, and a continuous short, and its not going to affect anything anyways.
Now put in the series AC caps, on AC leg of FWBR, which knock it all out of phase - and it is already "way out" of phase; in fact "bucking" with the "cancalling series" way of connecting the two coils on each side of the rotor that face one another.  (similar to GRAY motor coils now but other subject)
And now, you want to knock it out of phase some more, to get themselves "back around' to the point it becomes 90 degrees out of phase, and so that now a resonate condition between the two coils exists, and the coils since cancelling, are acting in a "virtual" realm of operation too...
But they ARE resonating and the voltage climbs sky high, and the caps fill up...and there is nice sinewave too, like Ben jsut showed, regardless of in what sort of dimension they operate in.
My take then, is what romero did in similar fashion,  but not using the AC caps in series, is knock the coils back into the 90 degree resonate condition with the AIRGAP RATIO between upper and lower coils/cores and passing rotor magnet....for example, have lower airgap greater than upper and its all out of phase to one another how the coils energize...so they will induce at different "rates"... have airgap the same and its the same phasing and induction is the same.......so he didnt use the AC caps and did it like that unitl he found the airgap ratio between upper an dlower coils to where the coils would take off and resonate.  thats why he said he adjsuted that airgap between the rotor magnets and coils hundreds and hundreds of times!! (all makes sense but dont know for sure if htis is right as usual)
Then, the helper magnet behind the cores woueld accelerate the rotor as additional mechanical-boost since they are distanced to flip polarity of core at the TDC point so rotr will not pull back when coils energize...
Anywasy that is new theory and trasnslation of what you have been saying to do....thanks to JasonO for asking the simple questions and getting the simple answers so I can understand and everyone else too and way to go Ben eh
