Muller Dynamo
0 Members and 31 Guests are viewing this topic.
romerouk
Quote from: EMdevices on May 08, 2011, 01:55:30 PM
RomeroUK,
thank you for your previous answers and new video.
One question I have is:  does the device operate with the stator magnets reversed?  Have you tried that in the past?
EM
Does not operate with them in reverse, even if I turn one the system goes crazy.
As I said before they all work togheter.
Now I am wondering if I will add the missing magnets not to affect the system and make it worse than better. I should receive the ordered magnets day after tommorow and try them out.
nul-points
Quote from: nul-points on May 08, 2011, 12:27:55 PM
the convertor only NEEDS to stop any EXCESS energy going to the drive coils
so ALL additional excess is available to power any external load(s)
Quote from: poynt99 on May 08, 2011, 12:36:29 PM
But I agree, for the best efficiency of power transfer to the load, it should be placed pre DC-DC, as long as the load can handle the worst-case power surge possible going into it.
Quote from: k4zep on May 08, 2011, 12:55:21 PM
but you could put a load across the Cap ahead of the supply (I think you mentioned a 50 watt load at one time)  and keep loading it down till you had it down to about 6-7 volts at 12VDC into the motor from the switcher and it would show how much power is really available!  I suspect more than you think.
Quote from: romerouk on May 08, 2011, 01:24:59 PM
before the regulator I have about 15 volts, but I could use 2 10w bulbs in series there.
so that seems to be a concensus then...
1) the DC regulation only needs to transmit, & consume, sufficent energy to maintain the motor at a stable drive level
2) ALL *available* extra energy produced by the system can be made available to a load BEFORE the converter/regulator - as long as this doesn't compromise (1)
as Alexandyr would say: "Simples"  ;)
np
http://docsfreelunch.blogspot.com
EMdevices
thanks for the answer Romero,
the systems is definitely a fine balanced one and it's not just one thing that makes it work,  that's clear to me now.
EM
infringer
Excellent suspension test RomeroUK!
You could easily see that nothing is hidden in this device.
Finally you will want to record with maximum audio all sounds around you you may be heard.
This is to be done to prove that you are not overlaying another audio track to protect the fact that you are not trying to hide noise of someone off screen trying to hide behind you that is making this spin with an air hose.
If you could I would record this with a nice big mirror in front of you and to hide your identity I would wear a mask if you are worried about this. This would prove that you have no help of any sort other then possibly a camera man with a camera!
To totally prove this works there are two more things required in Suspension test two and I would call it suspension test final undeniable 100% evidence of overunity.
Do the supension test 1 more time.
Without cutting away pop open the DC to DC converter.
Then Discharge and Tear open the capacitor showing that it is impossible to have hidden any battery.
Also show the underside of the device as I believe this has not been shown yet! with the black rotor you could have a motor and a battery underneath it without anyone knowing.
If you complete all of these things without cutting away which you may need some help from a camera man to complete this task you have proved overunity and it will nearly be undeniable.
With the exceptions of:
The few who are just here to make life hard on you they will say anything to disprove your discovery. They are all getting payed money to constantly refute claims and put people off the path of enlightenment.
They may say that you are somehow transmitting wireless electric or whatever but most people here will know better because you do not have the correct parts wired in to make this happen.
RomeroUK this is indeed your device and once we all get it replicated and are generating energy you will be handsomely rewarded with Donations coming in from around the globe! I have with me an electronics engineer that I live with and he will be a great help with the replication process once I see some solid replications built.
Thank You so much for sharing a possible solution to a world wide crisis.
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
erikbuch
Hello everybody!
This is very exiting, I have been following this thread since first posting, and I must say, You guys are doing some great work here. Of course specially to RomeroUK!
I thought I should throw in a suggestion for testing, what about adding another switching powersupply, parallel to the one hooked up. (same kind) And see if you can load that one any harder than the one you are using now? Kind of separating "motor circuit" from " load circuit"
Just a thought, but might be on the wrong field here  ;)
Greetings from Norway to all!  ;D
erikbuch
