Muller Dynamo
0 Members and 115 Guests are viewing this topic.
Arthurs
Thank yfree timely response:
    I tried: Connecting Bottom-Tail to Top-Head.
    But: this connection the rotor does not rotate.
Arthurs
Hi mariuscivic
Thank you for prompt response,
I will follow your help,keep trying.
e2matrix
After switching wires as yfree suggested did you also try reversing the input to the coil pair by switching  positive and negative?  Not sure if that may help but since it won't move it's an easy thing to try.
yfree
@Arthurs
You probably had it connected as I suggested, because connection in Figure B should not work. It is very easy to mix things up.
With two coils in series, you are delivering two times less power to the rotor, compared to a single coil. No wonder it turns slower.
With two coils, rotor speed will increase when you increase the voltage.
yfree
bolt
Drive coils need to be in phase. They can be parallel cap tuned for resonance operation. Current will drop as RPM increases.
Generator coils needs to be bifilar wound. You can have more than one pair of bifilar in one coil like 3 or 4 pairs and each matched for null and diode plugged to common bus as a COPY of same flux.
You should check by frequency generator they appear "dead" to in phase pulses so the self cancellation is 100% perfect.  The rotor and back end magnets align and flip the domains between two states within the non linear BH region.  The cores (iron power, ferrite or metal mix) acts as a ZPE proxy its critical to the operation. Romero scope shot reveal 2 times period of zero point flat followed by positive and negative pulses.  Pulse goes high on approach then low. This is ambient energy there is no BEMF.  Bifilar coil makes out of phase VARS creates electrostatic tensor. It acts as a single large capacitor that is being charged!  Its a Time Energy Pump as time is swapped with space and Hertizian understanding swapped to longitudinal aka Scalar.  Where RLC simply leads to OU where RF understanding of power factor correction is taken to ZERO.
Do not think of them as coils making current they are NOT they become capacitors when induction is made NULL. Capacitors can be charged with JOULES. Joules are quite useful to us and can be moved to another cap called a Dump Cap where you can measure the work through a load.
No wonder Romero left the country i think he has given up all hope! Before anyone asks no i can't get involved building this yet i got enough to do with HHO Gensets and Kapanadze which i just started so it will be around Xmas earliest before i get chance to make a muller.
