Muller Dynamo
0 Members and 87 Guests are viewing this topic.
konehead
just had farily dumb but maybe good idea and the L2 coil/choke/ballast in the sonedi cirucit could be a "top" coil, and the coil being induced by rotor magnet be a "bottom" facing coil with rotor in between (or vice versa on which coil is top or bottom)...wonder what that would do.
maw2432
Quote from: konehead on July 04, 2011, 02:35:25 PM
Thanks for doing the circuit.   Same questions I had...  I hope he comes back and tells some more about it.
keykhin
Quote from: konehead on July 04, 2011, 02:30:22 PM
Here is the sonedi circuit re-drawn to how he says to do it but not sure about a few things like mentioned in notes
The circuit that sonedi propose is a ultra efficient modified Buck converter and works only with pulse width modulated signals. I don't think it will work on coil shorting  :-\
Thaelin
At all:
   Well did a run of the machine today. Attached is a piss poor pic of the wave form. Seems to be almost the right thing to me. ??  Output under load, its self, is 10.4v with a 10000uf cap on it. Still not enough to make it motor its self. No tuning at all tho. Just for fun. Now I can justify ordering the $150 worth of plastic parts laser cut. This time, plain wire coils as I need a bit more ohms in the drivers and more amps to the output. Onward.
thay
added:  The pic is across one coil pair before the fwb and the output fed back to input with a blocking diode pair to keep it from seeing the battery voltage. So true output from the coils.
Magluvin
Hey Thae
In your scope shot above, at 5.8 square divisions from far left of picture edge, is this between the magnets or is it tdc?
Thanks
mags
