Muller Dynamo
0 Members and 40 Guests are viewing this topic.
romerouk
Quote from: neptune on May 05, 2011, 08:58:14 AM
@Romerouk .Can you please tell us more about your magnets . Size , grade , source of supply ? and could you please comment on my question re multistrand wire . Re the coil cores . Are these just pieces of ferrite rod from an old radio , or are they commercial cores ? Sorry about all these questions , but we need as much info as possible to replicate .It would seem from the video that your battery is 17 Amp hour . So if you dispensed with the machine, and connected that lamp directly to the battery , one could reasonably expect a run time of about 9 hours until the battery voltage drops to ,say , 11volts . That is if the battery is in good condition . However you say that the machine has run for several days without substantially discharging the battery .If this is the case ,you can forget about analysing complex waveforms .In my book , this shows indisputable proof of overunity .
@nul-points . Yes fine cycling weather , thanks but very windy . On the flat lands of Lincolnshire , the winds are our mountains ...
The magnets are 2cm diameter with 1cm thick, not very sure about the grade, I think are N38, I have bought them long time ago.
The reason to use multistrand is that most of my devices I built I used multistrand.
Some tests from other projects before showed me that using multistrand wire I get better results.
Another reason is the type of wire I had when I started the project adn also much easier to build the coils when the wire is more flexible. I think there are 7 wires in(I am not home now to check).
The ferrite rods are recovered from computer PSU, used as filters with copper wire on them. I do work with computers and all PSU I need to replace I get the goodies out before disposal, free source for many useful components.
The battery is 17 amp but it is about 5 years old, not very good but still works.
Regarding changing the driving coils... I prefer to keep it as is, I am happy enough with the results, no need to proove anything, I know it works. I started this project not to get super power but to see how it works and if it works, so far results are good enough. I bought a DC/DC converter today and this evening I will try self looping...
romerouk
Something similar with my setup but a bigger scale
http://www.youtube.com/user/NewSpaceTechnology#p/u/0/JdCSbLdKVJw
"Perpetual motion is stored in the magnets.
The Magnets ARE the Motor."
"By cleverly counter-balancing their equal and opposite reactions to each other, in space and in time, partly by mechanics, partly by timing, partly by circuitry, and partly by material science, Mechanical / Electrical work can be extracted from them sufficient to show so-called Over-Unity production of Net Energy."
"That means, efficiency greater than 100%,
an actual amplification of the available energy
as opposed to a net consumption of the energy."
...... Bill Muller
woopy
Hi Romero
Thanks for advice and sharing.
I hope all the best for the LOOPING
I am gathering the matos to replicate (have to make some ordering)
Can't wait for your result
Good luck
Laurent
neptune
@Romerouk. Thanks for your additional info , much appreciated . I would like to work on a replication , but am a bit limited financially , and have very poor eyesight . I was actually wondering if it would work with ceramic magnets from microwave ovens , as I have lots of these.I built a 50 watt wind generator with these . I ultimately would like to build an OU machine with at least 100 watts out .Could I use old radio ferrite rods as core material?When it ran for several days without discharging the battery, did it have a load , or not?
       This machine consists of two parts , a motor and a generator . Which one is OU ? My money is on the generator . So we need to drive it with the most efficient motor available .Is a pulse motor the best choice? I don't know , I am just asking . Maybe a conventional permanent brush motor is more efficient, or a brushless ? Whatever motor we use , it needs to be direct drive , to eliminate transmission losses . Also someone on another thread quoted a mathematical formula to calculate the ideal coil-magnet ratio to reduce drag. I will post it later if I can find it .An afterthought .The pulse motor could of course be made more efficient by recycling the back EMF .
nul-points
Quote from: neptune on May 05, 2011, 12:58:30 PM
hi Neptune
have you seen any of Prof Kanarev's work?
he recently claimed to have created a self-running hybrid fluid/electromag motor/generator - details on PESwiki (& here on OU.com, somewhere)
not much detail forthcoming yet (in English, anyway) - but there was *one* short paper where he outlined something of his theories
he suggests that once a motor has been run up to speed then the most efficient way to continue driving it is by applying pulses
so it *could* be that you should hedge those bets on the generator...
...and also get one of Kanarev's motors installed on your bike - for when you meet one of them there Lincolnshire 'Mountains'!  ;)
worth checking out?
all the best
np
http://docsfreelunch.blogspot.com
