Muller Dynamo
0 Members and 211 Guests are viewing this topic.
Scorch
Just a minor progress report.
Went ahead and modified the bearings by way of cleaning out manufacturer's grease and using light oil.
In terms of a long lasting device, performing daily work, I prefer not to do this because grease is the long lasting lubricant that slowly melts, and releases oil, as needed.
But in terms of an experimental device, and attempting to eliminate as much friction as possible, this is preferred and ok for short term use.
Also went ahead and performed a more precision balancing of the rotor.
Accomplished by setting up a pair of perfectly level straight edges then watching how the 'heavy' end of rotor always settles in one spot.
Then remove material from that spot by drilling.
Then repeat this trial, and error, process until rotor no longer stops at same spot each time.
Then entire length of rotor edge can be covered with tape, if so desired, to eliminate air resistance from drilled holes.
Then, of course, make better rotor next time that is properly centered and doesn't need so much balancing procedures.  ;)
Scorch
So, I took my current build, as it is, (see image) over to a meeting with some friends and those who are technically minded are showing a lot of interest.
But as it stands, right now, while it may impress some of them, I am not impressed.
It's really cool and a relatively well built design.
And I can see that it does have a lot of potential if I were to go ahead and proceed with attempts to actually replicate the device, this forum is all about, with cores, and backing magnets, and fine tuning to achieve a resonant system.
BUT, once again, I find myself very impressed with what quanta magnetics has just produced.
Using nothing more than a pulsed DC motor/generator consisting of rotors containing six magnets and stators containing six coil pairs, and simple switching to harvest the peaks of the sine wave, he is once again demonstrating a very impressive unit as featured in these two new videos I just discovered yesterday.
Part one-
http://www.youtube.com/watch?v=fI9aFUGtzU8
Part two-
http://www.youtube.com/watch?v=r5Ln5hogw6Q
And if I had an extra $3,500.00 to purchase the kit, and needed extras, I would do it right now.
But I also wish to replicate a smaller, desktop, demonstration unit that I can take to meetings and encourage others to investigate these things.
And, eventually, have a device useful for home power such as the devices offered by quanta magnetics.
In the meantime, I am very inclined to steer away from the offset design, drill my next set of stators to have eight coil pairs for my eight magnet rotor already built, mounted, and balanced.
And with another pair of rotors on the way, along with stator plates already on hand, I have enough materials to build a dual rotor system with sixteen coil motor and sixteen coil generator. Or, a single rotor system with four motor and four generator coil pairs.
And this saves money on ferrite cores, additional magnets, elaborate controls, tedious mathematics, tuning, etc. in favor of a desktop version of the Q2 dynamo what uses simple switching, and capacitors, to capture voltage peaks without slowing the rotors.
I already have most of the materials to do this BUT this is straying completely away from what RomeroUK built.
And I'm not sure if this the right place to keep providing updates for a build that will be completely different. . .
That is all, for now, as I continue to contemplate all the possibilities while staring at, and admiring, what just PMMG4HYBRID built.
hoptoad
Quote from: Scorch on February 10, 2013, 04:56:14 PM
snip...
snip...
Since RomeroUK's self running dynamo was a fraud, then straying away from his build can only be beneficial.
Scorch
Without the knowledge, of first hand experience, I cannot take the position RomeroUK's device is a fraud or not.
But I do have the experience of watching, and hearing, Zero Fossil Fuel's video regarding the potential resonance possibilities of this device.
See his video #285 titled: "Unlocking Muller Motor Secrets" in which he has been heard to say such things as "quite extraordinary", "it resonated", "the voltage spiked" and "I believe once this baby hits 88mph; you're going to see some serious stuff.".
And, to the best of my knowledge, ZFF appears to know what he is talking about and has never lied to me.
Whether, or not, an offset odd/even combination of magnets, to coils, would be required is an entirely different question.
But is, still, a very unique configuration which may have certain advantages. Just depends on what you want to do.
Quote from: hoptoad on February 10, 2013, 06:44:56 PM
avalon
Here we come again... new year, same old scam.
This guy is a known fake. He produced his first (fake) videos a few years back.
Subsequently he started his forum [underservice.org] where he leads his faithful followers to where no free energy is in sight. [This is not mine - I've borrowed it from another post].
As far as I remember, last year user 'trace_ru' offered RomeroUK to come out clean. When RomeroUK refused and kept on mumbling  'the men in black took my dynamo', 'trace_ru' published an entire dossier of the guy on RomeroUK's forum (which was deleted pretty quickly), including RomeroUK's background and his photos etc. etc.  Having said 'deleted', nothing gets deleted on the Net - I've seen posts re-published on other forums.
So I wonder how RomeroUK plans to dazzle us this time...
