Yadaraf
Quote from: DA on January 19, 2008, 02:59:47 PM
Testing by varying the height and distance of the stator is essential, of course.
Apparantly no one has yet considered changing the angle of the stator axle.  Having all the magnets spinning in the same plane almost guarantees no power gain.  This one dimensional approach has consistently failed.
Theory:
Al's device "worked" because his stator was accidentally mounted at a slight angle.  Optimizing this angle will produce more power than you know what to do with.  When you build your computer controled machine to vary the distance and height of the stator, be sure to include rotation in two axis as well.  Working with the stator axle always straight up and down limits you to one dimension, when you should be thinking in at least three.  Placing the stator at an angle to the rotor changes everything.  This is why you see some replications work and others fail.  While everyone is trying to be "exact" and keeping the rotor and stator parallel, the only ones that come close to working are the ones with the stator "a little bit off".  Make it a little bit more "off" and see what happens.
@ DA
I'm playing with computer-based automation of stator tuning, but only in X and Z.
     Q:  Relative to the rotor, should the stator be angled radially, tangentially or both?
     Q:  Also, at what point in Al's video does the stator appear angled?
Cheers.
Yada ...
vipond50
To All Replicators and Group
Today after reconfiguration of the Stator magnets to a dual bearings I had a approximately. "one minute" self operation of the device and maintained a constant RPM once Stator Sync occurred. Note: What I mean by " Self Operation' is NO outside added input to the device. I added the second bearing to the stator due to instability to each arrangement. The instability induced friction and consequently drug down the rotor speed. Also with the device i am able at any time during spin up to latch any of the three Stators at any given time. In addition this allows me to have any combination of the stators running in synchronization.
My next step is to spend the necessary funds to Source totally all Non magnetic parts i.e. Bearings, Fasteners, Rotor center support shaft, etc. to construct a higher quality device.
I also understand that this is a variant of the original concept, but basic Engineering dictates that this is the next step.
Happy testing and may Your Rotors Rev up  ;D
fritz
I think there are 3 clear optimization steps:
1) Finetune the position of the rotor magnets
(I don?t think that all this magnets have exactly the same strength)
or match the magnets out of a bigger batch with a
magnetometer - or use a reference stator with a newtonmeter
attached.
This first goal is to get a symmetrical, smooth rotorfield.
2) Finetune the position of the stator magnets
I think that the stator magnets have slightly different strength.
If you finetune the distance of each statormagnet to
the already adjusted rotor using newtonmeter or measure the
resulting field - you can compensate differents in stator magnets
and achieve symmetrical statorfields.
3) would be to balance rotor and stators in the conventional way.
Even slightly unsymmetry and slightly different strength in the used
material can have a huge difference in the resulting force.
Measuring the force and the field is the key to operation -
then it would make sense to alter the tilt/distance/force of the stator
magnets.
rgds.
Nutcake
Quote from: plasmasd on January 19, 2008, 01:49:38 AM
Well seeing as this huge drama has gone to the garbage, it needed a supporting big budget trailer. So I made this: http://www.youtube.com/watch?v=FOEfkESHb0w
;D
Brilliant.
Anyone written a synopsis on the story line yet?
and who wrote the screenplay?
I give it 5 kernels of popcorn.
ken_nyus
Quote from: vipond50 on January 19, 2008, 03:57:51 PM... I added the second bearing to the stator due to instability to each arrangement....
hey Bill,
Any chance of a photo of the new stator bearing arrangemenet?
