0 Members and 47 Guests are viewing this topic.
cub3
Quote from: znel on January 19, 2008, 10:06:42 PM
  Children, children, children... and you guys talk about Al's childish video then start a little pissing match all of your own.  Come on  guys, finish up here and get back to something productive.
znel, My apologies, surely you meant Girls, girls, girls........... all this hair pulling, scratching and bit*h slapping has to stop.
Real MEN would take it outside, as was suggested earlier.
Den
plengo
I cant believe I waisted my time reading 20 last posts thinking I will learn something new. I really wish this nonsence stuff would be OUT OF THIS FORUM.
Can we just keep the science here and move on? There are other threads for discussion such as emotionals, non-scientific, waistfull and simple stupid.
Fausto.
supersam
@at all,
shuttinup, shuttinup! just keep up the good work.
lol
sam
Bruce_TPU
Quote from: vipond50 on January 19, 2008, 08:13:56 PM
Quote from: btentzer on January 19, 2008, 06:10:58 PM
Hi Bill,
Good to know our bearings work, since we have the identical ones.  I agree that this is the first thing we change.  Super precision run about $6.00 each.  I think perhaps super precision, stainless steel, eh? ;D
Which magnets have you got for the rotor?  Have you ordered any N35's?
I would like to see a drawing of how you used two bearings for your stators.
Great job!!   ;)
Bruce
Hey Bruce
my mags are N42's 1/4" dia X 1/4" long, I stacked them(four) i did this so i could have some adjustably
I will post a stator disassembled for all to see the config.
have U come up with a non magnetic bearing from Mike" Even SS would be better that the all steel ones we are utilizing.
Yes, I definitely agree!  Though, I like the results with ours, thus far.  I built an ugly dirty model today.  I wanted to see how I wanted to connect the rotor, etc.  I learned a lot.  I used PEX flex .5 ID for stator holders, and used a dremel to grind a bit for a better fit for the magnets.  Bearings fit fine.
I drilled my rotor slightly off, so it has a nice wobble (I am just playing until the machined parts arrive next week, using Jason's accurate blueprints!  ;) )
I oiled the bearings and they are smooth.  I played this evening.  I saw it sync and have a sustained run of near 30 seconds, many times.  A very cool sight to see.  Sore but happy fingers.  And this with the ugliest setup on the planet!  LOL  No pictures or vids, until the real deal is here.
BUT I will say this...From what I have seen tonight, I am confident in the truth of Al's machine.  I think that it will be a matter of engineering.  I also want to use my N35's for the machined pieces coming.
Bearings, proper distance between stator and rotor (5mm) and proper distance of the plane from top of stator magnet to bottom of rotor magnet plane.
I do not think this "anomaly" is either the material used nor the bearings being steel.  I think it is solely the magnetic field interactions.  IMHO  That said, I plan on even looking into air bearings Monday, if Mike is there.  It is a holiday, but I will see.  I will post the info when I get a hold of him.
@ All
I am starting a debate thread.  If you have a beef with someone, you can take it there, and leave this thread for magnet motor discussion.  The fighting is growing old.
Happy days,   :D
Bruce
Omnibus
Arranged the rotor magnets just for the heck of it as NSNSNSNSNSNSNSNS and tried it with the three stators in various configs as well as with 2 and 1 stator, raising the rotor several times with washers. Rotor seems a little happier--wind down time close to 30s, stators lose rotation at higher rpm and only tremble. Now, back to the standard arrangement.
