0 Members and 46 Guests are viewing this topic.
Jdo300
Quote from: Omnibus on January 20, 2008, 08:58:49 PM
@btentzer,
Thanks. Will wait. I've already ordered N38 but won't hurt to have these N35's as well.
Another thing I'm finding to be quite important is the fixing of the rotor magnets in the grooves. Slight disparities seem to make a great difference in the behavior of the rotor. I'm reluctant to glue them because that won't make easy to exchange them. Had them press fitted into the grooves after sticking a piece of duck tape to them. I'm finding out now that isn't precise enough positioning..How do you fix them in place into the grooves?
Hi Omnibus,
A quick and easy way to secure them would be with hot glue. You can just heat it up to get the mags out.
God Bless,
Jason O
Lakes
I`m just wondering if the Neo`s were heated would this be a way to weaken them slightly?
crash_uni8
yes it would,but it would be far too hard to get them at the same strength plus they are toxic when heated...
Bruce_TPU
Omnibus
Funny, I'm using my business cards placed sideways and then press fit the magnets into the groove. Then I cut the unused part of the card with a razor blade. Seems to work for now.
OK, I'm seeing a slight change in the patterns of the rotor I was mentioning above when turning it slowly by hand. Other than that, this particular setup doesn't show anything unusual at the speeds induced by hand. I can make the stator lock AGW but that doesn't help the usual deceleration. The other setup I saw signs of effect with isn't with me now. Will try to do something with it probably by the end of next week. Will see. I'm, however, more interested in this one because it's an exact copy of @alsetalokin's save the proper magnets. Hope the ones I ordered will be closer to what's needed and will try them as soon as they arrive.
Thanks everyone for the help.
