0 Members and 4307 Guests are viewing this topic.
Omnibus
@CLaNZeR,
That's an excellent idea to arrange sending your rig to @alsetalokin for him to see if he can get it to work. Once it's sent back to you working you can help everybody else to set up his or hers properly constructed.
Jdo300
Wow did Al actually consent to that?? Awesome :)
Omnibus
Quote from: Jdo300 on January 21, 2008, 01:13:13 AM
Not sure. Someone proposed that and I found it a good idea. Wonder what @CLaNZeR thinks about it.
fritz
@Omnibus
Another idea I had was to turn the rotor with stators mounted
with an rpm controlled motor.
Using a stroboscope(which some capability to sync it with the rotor)
you can analyze the angle of the statormagnets vs. rotormagnets
at different rpm..... instead of static forces - you can see dynamic
effects caused by misbalance in magnetic or mechanical ways.
The shift between rotor and statormagnets @certain rpm is
an interesting parameter.
rgds.
geodan
Quote from: Omnibus on January 21, 2008, 01:16:41 AM
someone just threw that out to CLaNZeR..., Neither Al nor CLaNZeR bit ... good idea but dead for now...
