vipond50
Quote from: georgemay on January 23, 2008, 10:14:56 PM
Not sure if anyone noticed:
ALSETALOKIN
Can you spell it backwards? :D
Nope & Nope
Daaaa  ;D
MeggerMan
Hi Omni,
Never thought of trying the two different orientations.
I will do the same test and show the  results.
I have N42 1/4"OD x 1/2" rods and N38 6mm OD x 2mm discs (6 of these to make up the 1/2" - almost).
N38 spacing was about 28mm but I will do all the tests again and ask Al to do the same.
Also I will do the stator to rotor magnet test, Al did this too but could not remove the bearing.
Rob
hartiberlin
Hi,
I have not studied all the pages over here,
but what I have seen so far and from my own experience
a pure permanent magnet motor with just permanent magnets
without iron in it will not work.
I don?t know, if Al?s video is a fake or not,
but seeing his second video, where he throws
his dissassembled motor into the trash bin
makes me wonder, what character he really is...
For those of you, who have the magnets now and parts,
maybe you can now easily convert this to a Helmut Goebkes
type motor,
which I posted sticky over here,
as I think this still is the only way how to get a permanent magnet
motor working with the right amount of iron metal in it:
http://www.overunity.com/index.php/topic,3979.0.html
Bruce_TPU
Quote from: hartiberlin on January 24, 2008, 06:24:13 AM
(snip)
type motor,
(snip)
With all due respect Stefan, if after 6 months, working on this, and no one sees anything of interest, nor any acceleration, nor any continued running with increased times, I would move on.
But people have already seen the above and many of us are just now getting our parts.  No one has the correct rotor magnets, yet, IMHO.
So to think of taking all of our equipment, that cost a chunk of change and starting another project with it, at this time, makes no sense to me.
I read what you wrote at youtube about this motor, and I know that you think it is faked, but I do not, for too many reasons to list here first thing in the morning.
Warm regards,
Bruce
CLaNZeR
http://www.overunity.org.uk
