Bruce_TPU
Quote from: ken_nyus on January 24, 2008, 08:32:37 PM
Quote from: RunningBare on January 24, 2008, 07:52:37 PM
Can somebody please give reference to where there are additional magnets on the dampers?
I think it is from back on the bottom of page 110 from Robbie47.
From the new vid, the damper at the top of the video looks like it has something other than just a screw holding it down.
Yep, and it is not a magnet.  Blue_ hit on it some time ago.  It is a golf tee.  It is non magnetic and make it easy to move the damper around for testing.  Look at the center dimple.  A golf tee no doubt, and no joke!  LOL   :D
@ Rob
Strange that your N38's are 28 mm separation and my N35's are 28.5 mm (tested both ways, no difference)
@ Clanzer
It will be interesting to see your wind down test results with the identical alloy that Al is using, compared to the aluminum.
Also, if you could please ask AL to measure the separation from the black ends of the rotor magnets and the separation between the silver ends.  Jason can figure it out, but it would be far more accurate to have Al simply measure it for us.  This could also, make a huge difference between a working replication, and one that does not.   ;)  Thanks!!
@ Omni
Still no success finding a magnet with 30.5 mm separation.  We need to keep looking.
Cheers,
Bruce
ken_nyus
For the visual detectives out there, it seems to me that Al has painted one of the crescents on the outer part of the rotor black, from this image in the dual trace post over at Clanzer's site...
http://www.overunity.org.uk/ocpm/alsetalokin/symmetry_p1.JPG
You can see it flash in and out in the new vid.
Jdo300
Quote from: geodan on January 24, 2008, 08:47:03 PM
Quote from: CLaNZeR on January 24, 2008, 05:11:00 PM
Guys I am trying to do tests from peoples suggestions as well as doing my own experiments, I have been on this 24/7 for over 2 weeks now and will get around to various suggestions that I am taking note off, even if not replying.
My 6061-T6 1/2 SOLID ROUND BAR arrived today, so cut a couple of bits off and quickly bodged into stator, and yep it does make latching easier :)
Not done any wind down tests yet too see the difference between the normal Alluminium dampners and using these ones.
I was looking at the base tonight and following the OC PDF http://www.overunity.org.uk/ocpm/OC_motor_011708.pdf
I drew up another Base as I wanted a exact base with no movement to do some other tests, but it just does not look correct.
AL was saying about the 5mm spacing between the Rotor edge and the Stator outiside surround and stating that it is critical. At 4mm the air gap is too little at 6mm the Magnet looses sync.
Cheers
Sean.
@ Jason,
Can you please comment on this? it sounds like tolerances need to be pretty exact... Several of us are about to order rotor's / bases based on the drawings that CLaNZeR refers to here... do you feel that adjustments need to be made before we place the orders?
Thanks
Geodan
Hi Geodan,
I can't really comment on that image as I am not sure how he arrived at those measurements. What I can say though is that the set of blueprints and CAD models that I made for the unit were approved by Al. I am still waiting for my base and rotor to arrive in the mail (expecting to see it either Saturday or Monday next week). But I had my model CNC'd exactly according to the drawings that I made based on Al's comments on the dimensions. In case you didn't see the posts about it, look here:
http://www.overunity.com/index.php/topic,3871.msg70719.html#msg70719
@All,
After seeing Al's third video with the strobed images, I am very relieved to see that the stator magnet is rotating at a constant velocity. I have read about the many proposals to artificially reproduce the acceleration using motors. I've given some thought to this myself and it seems to me that we should look into actually locking the stator and rotor in a 4:1 gear/pully ratio. In this way, we can simply var the phasing of the system and then use a motor to spin the stator to see how that affects the power consumed by the motor. (But again, this is assuming that the stator velocity is constant as the video strongly suggests).
Also, now that I can analyze the stator magnet position with respect to the rotor. I can almost do some simulations to show the torques on the stator and rotor. But before we go there, we need to know if the rotor magnets are, in fact, off center in their slots in the rotor. I'll wait to see if Al comments on this but, if not, it would be a small matter to simply add that as a parameter in the simulation to get some preliminary results.
@Omnibnus,
Have you found out anymore information about the person who did the simulation graphs? I would be very interested in knowing what software he used to generate the results.
God Bless,
Jason O
Omnibus
@ken_nyus,
Speaking of video-detectives. Is it me but it appears that the right hand side rotor magnet in the pic you show is at 90mm from the left rim and 104mm from the right rim? Left hand side rotor magnet seems pretty symmetric.
Omnibus
@btentzer,
Will work more on this problem (the strength of magnets). Probably on Sunday I will have the virgin ones together with the ones I've already worked with and studied. It will be amazing if working with them a little bit affects their field as Stefan suggested. Will let you know immediately as soon as I get results. That's very important to study.
@Jdo300,
Don't have a clue although I'd like to know more about this simulation too. @btentzer mentioned it first here and someone else added that the simulation has been done by @hdeasy from Steorn forum.
