Omnibus
@All,
Just checked the magnetic induction values by having the probe outstanding at the same distance (10mm) from the surface both of the rotor and of the stator magnets. The data for the rotor graph are similar to those I posted earlier:http://www.overunity.com/index.php/topic,3871.msg74021.html#msg74021. The stator values, as expected, are lower (on the average between 150 and -230 gauss) than those in the link but are still higher than the rotor magnet values which is as required to qualitatively mimic the original. Both rod and ring magnets are stated to be N42.
I again emphasize that we need to know these magnetic induction profiles quantitatively and in detail.
cub3
omnibus,
Concretness, ask Al! :)
The Replication needs absolutness not generalisation, it's ability to succed is determined by its accuracy to the original.
This thread as well as others is becoming full  of unmitageted garbage.
The information showing the exact reproduction of AL's original device is what is required, with the differences that each replicator has.
Do you know if there is a true replicators site, without anylisis of spurious information by in accurate and non original replications, which should include a time line off all  of AL's modifications
@omnibus with consideration to you PLEASE re read earlier post s l o w l y . A spread sheet / database of what different replicators have. The Purists  and the Deviants you all try hard.
Keep on keeping on, but lock it down.
Den.
ps http://www.halexandria.org/dward124.htm
Omnibus
@cub3,
It doesn't seem that you're continuing anything to this thread. if you continue with your useless rantings I have no choice but to ignore you.
vipond50
Quote from: cub3 on January 30, 2008, 03:39:55 AM
omnibus,
Den.
Ok Cub3
I'll remove my Pic's and shut the heck up, after all " This thread as well as others is becoming full  of unmitageted garbage"
Well Said
B.
vipond50
Quote from: vipond50 on January 30, 2008, 03:46:51 AM
omnibus,
Den.
Ok Cub3
Well Said
B.
It is done
B.
