0 Members and 44 Guests are viewing this topic.
Omnibus
Quote from: Bruce_TPU on January 30, 2008, 08:16:16 AM
@ Bill,
Please repost your pictures, as I have not yet seen them.  Learn to ignore the rants of others, Bill.
@ Cub
If you want a spreadsheed, etc.. I say if you have the burden, go for it.  Rantings do not assist the effort.
@ All
Bill contributed greatly, proving that the rotor weight does indeed matter greatly.  This is important, to get our rotor weights to the exact weight given by Al.
Does anyone know how Sean's testing is going?
(Our correct sized rotor should be finished Friday and in the mail.  You have no idea how frustrating it has been.  My 6061-T6 alloy arrived yesterday.  I will have it cut and drilled today.)
Cheers,
Bruce
EDIT:
I just weighed my rotor that is 3/8" short of Jason's blue print.  Weight:  258 grams.   ???
Please explain more. How do you mean "3/8" short of Jason's blue print"? Is it the thickness or the diameter and is it with or without the magnets?
RunningBare
Just out of curiosity, I decided to see if I could get stator agw lock to the ring magnets in my newman motor, see image
The image represents looking down on the setup from above, the red bar is the motor spindle, the green is the coil, the black is the ring magnets and the grey is the stator lying on its side.
Sure enough I have got agw lock and it is still spinning merrily away as I type this, of course the newman motor is powered  :wink:
The rotor is also spinning merrily away in the same plane as the newman motor on the left hand side of the setup.
Just posted for a little experimental fun, btw the agw stator spin has been going for 3 hours now.
Gotta do something while waiting for Alsetalokin to make an appearance
canam101
That's neat. Does the Newman motor draw less current after agw lock?
RunningBare
Quote from: canam101 on January 30, 2008, 02:50:42 PM
No, approx 30ma without the stator in position and 40ma with stator, and it does not matter if its agw or gw.
vipond50
Hi Group
Ok, after thirty years of working in the Engineering field I finally retired. I put up with all kinds of crap like most working Engineers do. Now I don't have to. Arm chair Engineering is needed, as some folks do not have the resources or abilities to take an idea from the chair and develop it into a working proto type. The way i was mentored and trained was to be capable to do this. I understand why Al changed his proto from a bearing mounted rotor to a shaft mounted supported system and this is why i move toward this in the second device. I constructed my first device and saw a instability that was corrected in the second device. We really do not have a true specification to follow, because if we did i would have followed it to a tee. So that being said the evolution of my experimenting of the OC MPMM will evolve as my background and instincts guide me.
I do not want to influence anyone with there choices relating to this Sudo replication, I say Sudo due to the fact that a generalized guide has been developed, but the specifics are yet to be revealed by Al. It is my hopes that all who work this are successful and learn something. This is what life is really all about a quest for knowledge.
Enough Stated and I apologize for being a bit off topic.
I have attach the Pic's of my second device and will attempt to answer any questions relating.
Thank You
Best Regards
