Bruce_TPU
Quote from: Omnibus on January 30, 2008, 04:14:36 PM
@Bruce-TPU,
Do I understand it correctly, just the HDPE part (without the magnets and the bearings) of your rotor which is 3/8" short of Jason's blue print weighs 258g, right?
@ Omni
My current, incorrectly sized rotor, with magnets and two bearing weighs 258 grams.  I have a very accurate digital scale.
So....the correctly sized rotor will be of the incorrect weight.
@ Bill
Please PM me, if you can assist in making my rotor the correct weight at a future date.  Thanks!
Bill the tool man!   ;D
Cheers,
Bruce
EDIT:
But the question remains;  Why is the weight of our rotors off by so much, using same material, etc?  What or where is the problem?
Yadaraf
Quote from: robbie47 on January 30, 2008, 06:25:06 PM
Maybe a crazy brainwave, but I was playing with the ring magnets for my stator setup. They were mounted with bearings on a nylon axis.
I noticed that they act like a compass  and have always a preferred direction to North/South.
(checked with a real compass)
I double checked the surrounding of these magnets, no metals around for at least 1.5 meter.
The question that popped up in my mind is:
Does the geographical orientation of our rigs matter?
Note: I am not able to test AGW yet. Still waiting for the right rotor magnets here.
@ robbi47
Hey robbie,
I had the very same thought earlier today, but posted it at CLaNZeR's forum, because it is less hostile and more open to new ideas.  Point in case, did you see how cub3 was treated here?  It's sad that this thread has been hijacked relative to the OP's original query, which was very general in nature.
If you or your idea are treated hostily here, please don't give up (like I did).
Cheers,
Yada ..
Omnibus
Quote from: Bruce_TPU on January 30, 2008, 07:21:59 PM
@Bruce-TPU,
@ Omni
@ Bill
Cheers,
Bruce
EDIT:
Indeed, why is the weight of our rotors off by so much? That is one of the central questions that have to be addressed when talking to @alsetalokin.
Also, wouldn't your incorrect rotor, now being of the correct weight of 258g, be away from the stator not at exactly 5mm which @alsetalokin emphasized to be a crucial parameter (not 4mm, not 6mm, but exactly 5mm)?
We must settle this issue with the rotor weight once and for all as well as the magnetic induction profile around rotor and stators, before we can ever expect to observe the effect in the video, I think.
It seems that we're faced with fewer parameters to play with and adjust compared to other instances, say, compared to making a working Wankel engine, correct? Of all the proposed magnetic motor this one and @xpenzif's seem to be the easiest (having fewer parameters) to  optimize. That's why it seems so attractive.
FunkyJive
QuoteThe question that popped up in my mind is:
Hi Robbie
My personal thought is not - particularly as Al's original demonstration video illustrated the motor being picked up from the desk whilst running, and the earth's EM field is very weak in any case - though of-course I'm only applying conventional science in this case  :-\
It's probable that deviations in the flux density or field concentricity of the magnets will have a far greater impact on your motor.
Particularly good lateral thinking though  ;)
All the best,
FunkyJive
"Invention has its value, but discovery is priceless"
"Faith from the wealth of negative speculation cannot deny faith from the sparks of promising experimentation"
"A quest of impossible odds is not driven by expectations of what is achievable, but by the certainty of what is not"
"It is not weak minds that perpetrate misconceptions, but strong minds heading in the wrong direction"
"Experimenters seek understanding from achievement, academics seek achievement from understanding, whilst sceptics would seek to deny them both"
"Once the world was flat lest we should fall off. Once man could not fly as he was much heavier than air. And so we arrive at another threshold"
BD Townsend
ken_nyus
Is your rotor 18mm thick or 3/4"? I think this is maybe the biggest difference between the "plans" and Al's measurements.
Here's an actual set of measurements made right now.
Material HDPE
rotor diameter 144mm (5.6692?)
rotor thickness 18mm (.7087?)
distance from OUTER EDGE of rotor, on a radius, to INNER EDGE of magnet slots 13 mm (.5118?)
slots are symmetrically arrayed 1/4? nominal width, 12 mm depth (.4724?)
slots cut in a single pass with a 2-fluted end mill 0.250?
Also remember the 3/4 center that was later plugged with a piece of delrin (not sure what size hole was in the delrin)
And then the extra cutouts underneath for clearance for the bearing assembly, like Bill's setup.
