0 Members and 18 Guests are viewing this topic.
Omnibus
@vipond50,
Will do that as soon as my rotor arrives today and will let you know.
vipond50
Quote from: Omnibus on February 07, 2008, 12:58:44 AM
@vipond50,
Thanks Omni
i can only get one to line up, The other two are out 20 or so degrees. In the mean time i will try to angular measurements off my setup as well as Mea's off the pic.
AndreaGanora
Quote from: vipond50 on February 07, 2008, 12:38:16 AM
@ Bruce, Omni and Others
Was comparing my stator referencing Rotor magnets orientation to the attached Pic and could not come up with the same. Was wondering if u could look at your Orientations and supply some feedback.
Q.- Did Al accurately mark the N & S of his Stator Magnetics ?
Thanks
Bill]
@vipond50
Good you pointed this out , I didn't notice :-\
I think i can recall someone usking Al to chek if he had marked his mags correctly , and Al unswering that they could have been all marked wrongly colorwhise ( that meaning that black could mean either noth or south ) but that he doublechecked all of them and all stator's and rotor's mags showed to be  marked same colour on same poles and therefore to be consistent  .
Here is a pic of my rig , I've tried to let the rotor sit in the same position as Al's and as you can see it doesn't really match by spacing and angoular alignment of rotor's/stator's mags.
Note : All magnets on my rig are standard colour marked RED=NORTH and WHITE = SOUTH  - my rotor is ( EDITED shaved it tonight on the Lathefrom 20 down to 18 mm )thick HDPE - weight 8edited now weight 260 grams  included bearings so different design but allmost spot on about the weight )- 144mm dia. -  magnet housing groove 13mm deep by 7mm whide - distance from rotor's outher edge to magnet's housing groove inner edge 13mm - 1/2" dia by 1/4" deep centerholes on both sides of rotor , centerholes housing 2 SKF 624-2z bearings normal ferromagnetic same as the ones I use for the stators- dumpers made of anticorodal alluminum same dimensions as stator's mags BUT NOTE that the rotor's mags are K&J's D48 that are N42 grade and not N35 as appearently the ones used in Al's working rig , but I don't know if the different alignment could depend on this factor , i rather suppose that the rotor's N42 mags would anyway balance themselves respect to the stator's ones in the same way as the N35 would but not shure about that  ::).
Bruce_TPU
Hello Andrea,
A nice looking rig.  What materials are your dampers?  If it is not the 6061 T-6 I suggest you change to that.  Also use the nylon for the center screws of the dampers.  Or golf Tees.  Other screws will add to the dampening effect.
I am working on proper screws today, myself.
Good Job!
Cheers,
Bruce
Omnibus
@vipond50 and @AndreaGanora,
@WhiteLite brought up the question for magnets being off in the strobe video and @alsetalokin answered it here: http://fizzx.com/viewtopic.php?p=2188#2188. Obviously, there must be a similar problem in the device shown in the picture as well.
