Yadaraf
RE WhipMag history/construction and parts:
I find this large PDF to be the very useful.  It appears to have all of the dialog between Al and OC, as well as specs -- as they evolved.
... http://www.ospmm.org/whipmag/pdf/OC_motor_012708.pdf
Cheers,   :)
Yada..
Omnibus
@Yadaraf,
@overconfident's input is to be ignored altogether. It's only noise and gets in the way of proper replication of the device.
Bruce_TPU
Quote from: AndreaGanora on February 06, 2008, 10:44:36 PM
Quote from: Bruce_TPU on February 06, 2008, 10:10:47 PM
Incorrect -
I am not using Stewart-Warner Bearings for my Stators
Correct -
Order Stewart-Warner bearings of correct size from Mike, the bearing guy.
Small progress is good!
Cheers,
Bruce
@Bruce
I don't remember Al writing anyting about the Stewart-Warners beyng for shure the ones that worked properly as stator's bearing between the 13 he had, since he had some Stewart-Warners , but not enough of them , so he bought some other unlabelled ones . so is a good start knowing the maker of some of them but isn't shure they are the good working ones , at least not that I remember him mentioning  it .
just a notice  ;)
keep the great work up
Hi Andrea,
Nope, look again at what he says.   ;)
Al:
"I had 8, they are Stewart-Warner, and I had to buy 5 more from another source, they are unmarked."
I interpret this to mean that his original source for the Stewar-Warner bearings was dried up and he bought 5 more from another source.  (but still the same Stewart-Warner bearings).  And when they arrived, they were unmarked.  Thus no serial numbers, etc.  My bearings are all unmarked also.
Cheers,
Bruce
EDIT:
@ Ken
Thank you.  I will try Stainless Steel 4-40 from Lowe's.  I should not have to grind the head.  Still Stainless Steel.  I also need nylon screws for my dampers, not the brass I have.  Everything affects damping, magnetics etc. and as Omni has said, it must be tuned perfect and built/replicated perfect.  Only one on the planet works.  I take this very seriously as do many of you.  Let's make this happen.
AndreaGanora
@Bruce
Well better like that then  ;D
I must have miss interpreted what he meant .
Cheers
Andrea
here you find nice and clear pics of the device :
Omnibus
@Bruce_TPU,
That's splitting hairs. I also understand it the way @AndreaGanora understood it--he ran out of the  Stewart-Warner ones and had to buy 5 more from another, non-Stewart-Warner source and he doesn't know what exact source that was because they were unmarked. Now, if Stewart-Warner produces also unmarked bearings these new ones very well might have been Stewart-Warner as well but there's no proof for that. The only hope would be if Stewart-Warner is the only Canadian company producing bearings. Etc. ..., etc. ... I think we're trying to read too much into what @alsetalokin drops laxly here and there.
