0 Members and 65 Guests are viewing this topic.
ezzob
Well i think is time that Al say something, its all a big smoke screen ;)
And it cost people money and time.
Harvey
Quote from: crash_uni8 on February 08, 2008, 12:45:33 PM
hi everyone i was watching the video again and around 2:09 through 2:11  someone says something... does anyone know what he says?
http://www.youtube.com/watch?v=PIvZJ9xGutI
The background voice appears to be asking "Aren't those too high?"
8)
Bruce_TPU
Good Afternoon all,
Received MY rotor in today!  (Finally!  I am very happy!  LOL)
A couple of weights and measures only, for now.
Rotor Weight
228 grams
Magnet Weights
24 grams
Bearings
2 grams
Total = 254 Grams  I am very satisfied with that.  Only 4 grams short.
Stator Bearing Assembly Weight
10 grams  Perfect!
Separation between rotor edge and stator
5 mm  Perfect!
I still need to grind screw heads.  I will start on that tomorrow.  I hope for live testing next week.  I will have to use golf tees until I find the proper nylon 4-40 screws, for the dampers.
@ Sean
Are you using lubricant for any of your bearings?
@ Harvey
Is there a chance that Al's effect could be caused by induced current into the bearings, visa via the rotor magnets.  And then with the magnet above, together, the stator acting as a homopolar generator?
If so, then using a non conductive lubricant could screw up the works?
To lube or not to lube, that is the question!?!?   ;)
Cheers,
Bruce
Omnibus
@CLaNZeR,
Great videos. As always. I gotta tell you, the behavior of your rig is exactly as mine (I like the addition of the rosette in yours) regarding the AGW lock. Now we should consider established that achieving AGW lock isn?t a problem but that?s not the crucial factor for the effect of acceleration to appear as we were led to believe by @alsetalokin. There must be something else working in concert with the AGW lock to bring in the effect. The good news is that we only have just a few parameters to tinker with in exploring what that 'something else' might be. The bad news is that it isn?t straightforward to fiddle with the magnetic field which is one of the parameters or to second guess what exact company the proper bearings come from. One thing we may do, though, is to start from a lower rotor weight and start adding pieces of plastic or lead or whatever to see if we could reach a happier weight.
I?m not sure what @Yadaraf  is trying to achieve with his 5-th harmonic (as far as I understand that?s detrimental for the motor?s run) but it?ll be interesting to see how different your and my rig will sound having in mind that, all the rest probably the same, my base is thicker (almost 18mm) and your bearings come probably from a different source than mine.
P.S. You wouldn't have any rpm vs. time curves taken with your tachometer with and without AGW lock, would you? It'll be interesting to see how they compare at the very beginning of the AGW lock. I remember in your earlier graphs you published here there were some peculiarities worth paying attention, I think.
Omnibus
@Grimer,
You posted somewhere the following:
" I believe that AGW stator rotation is the point where power being consumed becomes power being gained. "
That isn't obvious, however. Could you please elaborate on that?
