CLaNZeR
Quote from: Craigy on January 12, 2008, 08:44:45 AM
ok will leave it running for an hour , but it seems a good system if you need to broadcast a motor spinning lol
Receiving fine this end. Will make a note of that link.
http://www.overunity.org.uk
Thaelin
   Good pic here PNW  stateside.  I have seen upwards of 50 on a channel at the same time.   Just check out perillo on ustream. He has quite a gang hanging out.
thaelin
canam101
Good pic, smooth streaming, here in Canada.
skymovingcloud
Quote from: Grimer on January 12, 2008, 08:29:46 AM
Quote from: Craigy on January 12, 2008, 08:18:23 AM
http://ustream.tv/channel/overunity-testing
just testing , can you connect and see if its any good? Broadcasting live from tenerife
Perfect in London. :)
second that, better than a screensaver ;-)
Bruce_TPU
I wonder if those of you in Australia will be spinning the rotor counter clockwise and the one stator magnet counter clock wise (the exact opposite of this hemisphere -Northern) to get your replication to work.  I would wager yes...   ;)  But we will see!
An interesting video, related, but not anti-gearwise.  I wonder if he spun another "master gear" anti-gearwise if it would make the whole thing self sustain also.  A lot of new ground open for experimentation.
http://www.youtube.com/watch?v=zRN-KCqlBxI&NR=1
Cheers,
Bruce
