0 Members and 36 Guests are viewing this topic.
Bruce_TPU
Quote from: sterlinga on January 12, 2008, 01:54:03 PM
Quote from: CLaNZeR on January 12, 2008, 09:36:59 AM
Started doing some weighing and wind down tests with NO stator magnets.
BTW I span it upto 4000 RPM without magnet just now and it started too lift off the table at 2500 RPM, so Blue Tacked the feet down and they are only just staying there at 4000 RPM, so be warned LOL  ;D ;D ;D
Hi Sean,
Are you joking or did you really see some possible anti-gravity effects?  I would think that this alone would be worth serious investigation.  Could you show that by video?  Unsecure the legs, and allow lift-off (with proper teathering and device protections in place).
Sterling
There is a HUGE difference between lift and inertia.  Think of "helicopter", not "anti-gravity".   :D ;D
Quote from: RunningBare on January 12, 2008, 01:58:56 PM
Hi Sean,
Sterling
Ever consider something as simple as down draft?
LOL!  Naw, it's anti-gravity, let's patent it!   ;)
Craigy
In the video there is just one stator , i made more stators but was so  excited after installing the first one that i ran out of time to install magnets in the others lol, what a plonker i must be..Like i said have the correct magnets on their way , but can?t sit here doing nothing
Any concepts or ideas expressed in this post are intended for the public domain. Free licence is given to reproduce and or modify provided it is for non-profit use. I don't want money, I want overunity!!
Localjoe
@Sterlinga
I remember seeing an old x craft that had discs on either side of the body that spun at high rpm's and provided thrust for the plane.  It was a real old plane tho somewheres in the 50's i think.  But supports that concept.
        Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
rotorhead
Quote from: Craigy on January 12, 2008, 02:31:48 PM
That's why I suggested trying cubes. Give you something to try while waiting.
CLaNZeR
Quote from: Craigy
Hi There , this is the playing before i get the correct magnets, i have the correct rotor on its way and the correct magnets, besides the stators themselves are 2 small neos drilled into a perspex disk, i am surprised i got anything with those..
Great Craigy, ya had too go playing TUT, ya could not wait for ya proper stator magnets TUT.
Right SOD you I am off too play as well hehehe  ;D
Well done mate.
Cheers
Sean.
http://www.overunity.org.uk
