hydrocontrol
Quote from: cub3 on January 15, 2008, 10:09:11 PM
Hydro
any chance you could post smaller pic's
Ive only got dial up  :-[
Den
Sorry about that.. Changed to 800x600. Should be a bit smaller and faster.
Bruce_TPU
Quote from: Butch on January 15, 2008, 10:45:33 PM
(Snip)
We all have our doubts about this,
(Snip)
We want to have the motor as close to a perfect copy as possible to the one in the video.
This bearing change will accomplish that.
Thanks,
Butch LaFonte
I doubt it, if what I saw in the first video is any indication.  You guys might try spinning the stator magnet faster than the rotor, this next time.   ;)
So, we all have our doubts about this, but probably not the same ones you do.   ;)
Good luck to your group,
Bruce
hydrocontrol
So what happened to CLaNZeR (Sean). He posted on his site http://www.overunity.org.uk
that he got the correct magnets and posted a video of it working (?) or almost working and now all the videos on his site are dead and no updates. Hope he is okay..
amigo
Quote from: hydrocontrol on January 15, 2008, 11:03:28 PM
Maybe we are eating too much of his bandwidth so he had to take them down? It's strange because when you click on a video it just opens a blank page for me, normally a plugin would kick in or an external player...
Freezer
He posts his videos here.
http://www.youtube.com/profile?user=overunityorguk
Seems like he's a lancer guy.  ;)  I'm a civic guy myself, but like lancers.
