My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
dhouse
Ok, we are using a diode system with a 15000 dc coil and using a 641ac supply.  It creates one heck of a spark outside of the engine.  When installed on the 4-stroke, single cylinder engine it will barely idle with gasoline, but it acts as if it is starving for fuel.  As soon as we switch off the ac bridge, the mower engine runs fine.  What are we missing with just regular gasoline?  We don't want to try water yet if we can't get past the gasoline.  We created an adjustable ignition switch on this as well.  Any input would be great.  Thanks
Super God
Maybe the voltage isn't high enough in the cylinder for the ac to run accross or the ac is snubbing out the hv spike.
>9000
dhouse
By voltage do you mean the DC side?  We are currenlty using a 15000vdc coil.  We have 641vac, which I assume would be plenty.  We have a 45000vdc coil, but it was shorting out our diode bank, so we put the 15000vdc coil back on.
xbox hacker
@rfsimoes:
Have you tried to use HHO as the fuel with the plasma spark?
alan
Quote from: rfsimoes on October 24, 2008, 01:28:08 PM
It's a 4 stoke 127cc 3HP briggs & stratton:
http://www.youtube.com/watch?v=EEs_XF5IWQY
I know that in brasil, alcohol is used allot in cars but don't know what kind of alcohol.
Must be bioethanol distilled from soya, for which the(ir) precious rainforest is being destroyed :(
