Thane Heins Perepiteia.
0 Members and 56 Guests are viewing this topic.
OUman
Quote from: OilBarren on April 19, 2008, 01:07:59 PM
The experimenter... then attaches capacitor powered roller blades...
Same issue in the analogy as in the real proposition. A capacitor is NOT a source of power, any more than the fuel tank in a car is a source of power. You have to charge up the capacitor, the same way as you have to fill up the gas tank. And that requires a source of energy. The energy always has to come from somewhere.
JustMe
Quote from: LarryC on April 20, 2008, 08:23:02 PM
Hi JustMe,
How are you getting 600 X 400 at 46.71 KB, when I'm only getting 46.88 KB at 320X240?
Thanks,
Larry
I'm better than you.
Good luck with all that, and have a great day!   ;)
P.S. What software are you using?
adlep
For pictures,
You want to use this software:
http://www.irfanview.com/
Open up the picture in it, resize the photo to the desired resolution, and finally compress the jpeg. Most of the time the quality 7-8 is sufficient.
gotoluc
Quote from: OUman on April 21, 2008, 07:07:13 AM
IT IS JUST A POSSIBLE AREA OF RESEARCH...
A LOW IMPEDENCE - HIGH CURRENT COIL IS "CHARGED" BY THE APPROACHING MAGNET & STORES ENERGY IN THE
ELECTROMAGNETIC FIELD & CAUSES DECELERATION.
AND THE OPPOSITE
A HIGH IMPEDENCE - HIGH VOLTAGE COIL  IS "CHARGED" BY THE APPROACHING MAGNET & STORES ENERGY IN THE
ELECTROSTATIC FIELD & CAUSES ACCELERATION.
BTW - IF WE KNEW WHAT WE WERE DOING IT WOULDN'T BE CALLED RESEARCH.
Thane
gotoluc
Quote from: JustMe on April 21, 2008, 09:54:43 AM
IS IT SAFE TO ASSUME YOU HAVE RECOVERED JM?
Thane
