Thane Heins Perepiteia.
0 Members and 25 Guests are viewing this topic.
aether22
Quote from: mark_my_words on June 18, 2008, 02:04:37 AM
;D
Good you agree. So what's the status on your findings sofar?
I recall a list of tests you were about to do. Can you give me/us an update?
I made a long list, then I realized I needed to have results that would clarify not confuse and made a  short list, and finally I figured that one experiment was better than all others and so I am trying to replicate Vince's test where he measured a torque increase on the motor housing. (I still plan of doing the others naturally but it tops my list)
Nothing to report yet though, still got glue drying on the ball bearings (being set into wood) and I may need to visit a hardware store before I finish yet, but I should get it done for tomorrow.
Also I am very interested in Jeff Cooks device, he is now selling them and it seems his steel coils could be used in a Thanean generator to possibly great effect.
LarryC
Quote from: aether22 on June 18, 2008, 02:36:06 AM
Hi A22,
What is Jeff Cooks device?
Thanks, Larry
aether22
Quote from: LarryC on June 18, 2008, 05:59:41 PM
Hi A22,
Thanks, Larry
http://www.jeffreyncook.com/jeff%20cook%20effect/jeff%20cook%20effect%20video.htm
I followed it from the very beginning many years ago, he first claimed it created a gravitational like pulse similar to the Morton/Podkletnov/Telos experiments (in reality an aether pulse), although the effect seemed to be hit and miss replication wise.
Then more recently he had announced that he can get a magnet to float in air above or below a modified version of his device.
This should not be possible according to conventional physics due to Earnshaw's Theorem of magnetic instability, what he claims is that he can make a steel coil out of very thin wire (which I now believe increases aether velocity) and have a permanent magnet repelled from this coil which can only be explained by superconductive currents in the steel coil.
Exceptions to Earnshaw's Theorem:
Conventional: Superconductor, AC Eddy current induction, Magnets used with diamagnetic materials, Permanent magnets with controlled electromagnets to maintain balance.
Unexplained: Levitron, Jeff Cook Effect.
Like the stator coils in Thanes device Jeff's coils have an aether current induced in the wire due to the presence of a magnetically sourced primary aether flow through the coil, and so I hope to make one of his coils and try it on Thanes generator as both effects would be present at the same time.
Jeff Cook is now selling a thing he calls a 'Wizard lamp' which is an implementation of his discovery, a green glowing ceramic magnet floating above or below an arrangement consisting of one of his steel coils and some other magnets. ($29 rrp but he is selling 6 of them for $105 USD)
LarryC
@A22,
No problem. Threw a Jeff Cook magic lamp together. Not green glowing, could be painted, but easy to build. 18 Gauge wire coil (not 30 as indicated. Slow aether?) in original package. 3- 1" by 1/4" neos all with same pole facing inward. 1- 1" by 1/4" neo floating in the lee valley container, with lee valley green foam packing around the container keeping it centered. Cool, my first anti-grav. Turn it upside down and the neo just hangs there.
Regards, Larry
aether22
Quote from: LarryC on June 18, 2008, 08:49:38 PM
@A22,
No problem. Threw a Jeff Cook magic lamp together. Not green glowing, could be painted, but easy to build. 18 Gauge wire coil (not 30 as indicated. Slow aether?) in original package. 3- 1" by 1/4" neos all with same pole facing inward. 1- 1" by 1/4" neo floating in the lee valley container, with lee valley green foam packing around the container keeping it centered. Cool, my first anti-grav. Turn it upside down and it just hangs there.
Regards, Larry
To state the obvious it's not really antigrav, at least not at that point.
And to state the other obvious point, the magnet should be able to float without touching the sides of the container.
Nice work, now can you remove the container and still make it work? (or at least verify that it can float without touching the sides)
Still it looks like you have it working or else the magnet should flip.
Now to bring this back on topic try using it (minus the floating and possibly backing magnet, but keep the side ones maybe) as a generator coil, bring it slowly near the rotor and see what it does. (it may plausibly cause acceleration further away and deceleration closer or something)
