pulse motor and transistor problems
Started by jasonspinmaster, February 08, 2008, 03:52:00 AM
Honk
By an oscilloscope or frequency counter
Magnet Power equals Clean Power
pese
ne 555 wil never go to 0 volt saturation.
take an dvm . aoutput to groeund . if voltage is over 0,55 volt = the transistor will conduct alltime.
If from NE555 voms out at lowes polt 0,5-1,2 volt , then use an 1n914 /41440 (4007) in serie from transitors-base to ic ( also this current limiting resistor aswell the rbe (that setfan talked about ist)
Pese
jasonspinmaster
jasonspinmaster
when i place the black probe on negative off the battery and the red one before entering 555 timer, on pin 2 and i get a reading off 0.12.
when i place the red probe on to the output off the 555 timer , after the 200ohms 1 wattresistor i get 9.45 volts
gezgin
I have seen miracles happen to men and women in all walks of life all over the world. Miracles will happen to you, too?when you begin using the magic power of your subconscious mind -Joseph Murphy
