Peter Davey Heater
Started by storre, February 09, 2008, 11:00:32 AM
edelind
@all
Since I last posted here I tried a few things regarding Davey heater and here are some conclusions:
First, there is something indeed with this device when the inner bell reaches resonance. Even I was not able to reach full resonance (due to misleading frequency data on my side), the heating process amplified at the proper distance between the bells (about 4 millimeters, as stated in the documentation). Also another mistake that I made was that I made the outer bell bigger (longer) than the inner one. This design made steam building up inside the outer bell and by pushing the water down, disconnected the inner bell from contacting the water.
So always made the inner bell bigger or have holes in the top of the outer bell for steam venting.
After seeing how my device worked and studying the Davey's movies, I concluded that in his last design, the sphere is the inner "bell", the resonator, and the top bell is the outer bell (there is no "protection" bell, as in the first sketches using semi-spherical bells). The sphere has that hole at the bottom, because it needed tunning, so it has to be machined. The covering plate I think it's just a try to make the sphere back as perfect as possible, but still not affecting its resonance.
Also, there is a problem with the voltage of the mains. At the so small distance between the bells, we face a process that normally happens outside the resonance too: the device will start heating the water by dragging a lot of amperage, somewhere beyond 20A. So either the resonance will cause this effect to be dramatically reduced (as a previous poster suggested too), either we should go for a smaller voltage (or else there will be no efficiency).
So my future tries will involve a better tunned inner bell with a smaller voltage. Maybe also a spherical design too.
Overall, I think Davey's device uses the same principle as WITS' water heater, just he tunes his device to the mains frequency, while WITS is going with the frequency after the sphere resonance. Of course, WITS' device is more efficient, as it resonate the sphere at its fundamental frequency, while Davey's is running on an octave.
See the WITS heater here:
http://youtube.com/watch?v=ZxnEQssJ4FQ
Regarding the patent, I say forget about it, as it's early work and even Davey dropped the idea long time ago.
edelind
Quote from: Nihilanth on May 27, 2008, 08:48:45 PM
Has anyone made any progress on this yet? I'm eager to try it, but I don't know where I could get bells that resonate at 60hz. I was thinking of visiting this bicycle shop near by because they might sell bicycle bells like what Peter Davey himself used, but once I'm there how do I determine the resonance frequency of the bells?
If this thing gets completed, then what are these good for, besides boiling water? Do you intend to use them to replace your water heater, or power things with a steam turbine?
Forget about bicycle bells! I think they were different back then when Davey used them. The present designs are not semi-spherical, but have multiple radius, more like a part of a sphere connected to a cylinder. This will give you multiple resonating frequencies which interfere one each other. Even you'll made them resonate somehow to a multiple of 50Hz (or 60Hz in US), you won't be able to find an outer bell with a diameter +1 centimeter on all sizes. You can see Davey's bell on one of the movie (or pictures) and they are all bells with a single radius, most likely stainless steel.
Also you should not look for a bell that resonates at 50Hz, as it must be huge, but one that resonates at a higher octave of 50Hz (an integer multiple, the best are powers of 2).
For tunning see this interesting link:
http://www.physics.brown.edu/physics/demopages/Demo/waves/demo/3d4055.htm
@all
A good idea is also to check your mains frequency before you start, as I had the surprise to measure 56Hz here.
nul-points
way back in the 1940s, either Peter Davey, or someone he worked with, discovered something important enough for him to submit a patent for it
the patent application expired after 1 year - it was never pursued!
although Davey went on to build handheld heaters for himself & modified the design - he obviously never believed he had found anything as significant as the first discovery - there were no more Patent applications after the first one!
what does this tell us?  it says that the most important features already exist in the first patent!  ie. Davey modified the design in a way that was unimportant to its operation
if we ignore the only Patent we have then we start wasting a LOT of time
Davey has already admitted publicly, on the video, that he's keeping something back
the only thing which is in the patent, and which he doesn't talk about in any interviews, is the loose arrangement of the electrodes
(the Patent begins by saying that concentric element electric water heaters are already a known art - the novel features of this one, at that time, were just the the rapid operation, the loose electrodes and the safety aspects)
in general, the current draw depends on the electrode gap - more gap, less current - less current, less heat
so, if there is anything anomalous happening at all in this heater, i strongly suggest that it's to do with the only thing which Davey DOESN'T talk about - the looseness of the electrodes - they can vibrate
note that in the Patent they don't have to resonate, or be tuned - they can just vibrate
this will happen either with the mains freq. or with the bubbling action of the steam & water - tests will be needed to see which is more important
the very small outer 'bell', between the handle & the sphere, is not a part of the heating process - when the water boils, steam & hot water bubble out the top of the heater, as cooler water enters at the bottom
that small outer bell is there to deflect the steam & water back down into the glass/cup & give some protection to the user - it doesn't need to go under the surface of the water (see the 'Twister' photo above), in fact, as a vent it SHOULDN'T go under the water
NerzhDishual has made a start (& already got some near OU results!) - build on that experience
i bet ND was too good a constructor to leave anything loose - am i right?
so, repeat the experiments with one or both loose electrodes (may have to be loose electrically as well as physically - see my comments above about possible mechanical SCR action)
maybe increase the electrode gap if it's pulling too much current
start testing - run some tests with anything concentric (bells, tubes, cones, whatever) - vary the parameters - look for a performance curve - find which parameters can be tuned for improvement
don't spend time with acoustic tuning of bells - until you know for a fact that bells are actually necessary!
...was i little too outspoken there?  ...not like me at all!  i just don't like to see people wasting their valuable time & effort  ;)
good luck
sandy
storre
@nul-points
When I see videos like this, it makes me think that resonance is important. Even with loose electrodes and bell, wouldn't it vibrate easier if it was vibratED with it's already naturally occurring frequency? Like this glass does in this video.
http://www.youtube.com/v/17tqXgvCN0E&hl=pl
Does anyone have bells the size of the ones he uses when he is playing the piano? It would be difficult to duplicate the size but it would be interesting to see what frequency it is or close to.
The octave (50Hz, 100Hz, 200, 400, 800, 1600) I think are the strongest resonant relationships but you also have the minor 3rd and 5th overtones that are strong. Maybe better to vary the frequency of the mains. I have an audio frequency generator in my house and I can turn up the sound and scan through it's frequency range of 40Hz to 3KHz and hear different things vibrating depending on the frequency. What options are there for varying electrical frequency besides this?
http://en.wikipedia.org/wiki/Variable-frequency_drive
Then make one of the bells a little lose like nul-points suggested and play with the frequency while monitoring the temp of the water.
http://pl.youtube.com/watch?v=zWKiWaiM3Pw&NR=1
edelind
@nul-points
Quote from: nul-points on June 05, 2008, 08:55:59 AM
There is no "twister" in that photo. Watch it carefully and see that the apparent twister is just the continuation of the wire that the third hand is inserting into the glass, most probably a temperature sensor (I suppose it's the hand of the DSIR professor that tested the device).
Watch the video again also and see that there is no twister:
http://video.google.com/videoplay?docid=-1527526922275986120&hl=en
Also notice that the boiling actually starts when the top bell hits the water. So that's an electrode too ;)
