My heat generating pyramid - picture
Started by PYRAman, February 15, 2008, 04:21:08 AM
PYRAman
Yes the power of the pyramids was used by the oldest pharaos to justify their power over the people by making them appear as having supernatural powers. But only the most old pharaos knew how to use the Great Pyramid, sometime in the history they closed it hermetically. The power of the newer pharaos was given only by tradition, that is why it finally collapsed. They could not demonstrate their supposed powers to the people.
Quote from: sparks on March 01, 2008, 01:02:27 AM
     Nacl crystals are pyraelectric.  When heated they will develops an electrostatic charge.   The pyramids of Egypt look like some kind of scam by the religious orders of the time.  Enslaving people to build monuments to the man made God pharoh dynasty.  What a crock.  The Egyptians had battery technology and probably alot more that we don't know about.  They probably used battery power to emit a light out of the shafts as well as resonating chambers with some sort of minor explosions going off to convince the working joes that there were big things doing in the graveyard.  Priests sneaking around fillingup battery resevoirs and throwing switches.  Wizard of Oz kinda shit.
  Below is a link to salt water burning.  The water is exposed to rf and it burns.  Must be nasty though if chlorine gas is coming off.
http://www.youtube.com/watch?v=h6vSxR6UKFM&feature=related
PYRAman
Nice work, my healing pyramid looks like yours, but I did not paint it.
Quote from: spacetrax on February 29, 2008, 01:01:10 AM
Hi@all,
I finished my russian type pyramid, I made a 7 ft. high piece and after some hours of pondering  I decided to spend at least 15 minutes inside to see how it feels.
Well, against all expectations, it worked in some way. I remained in the pyramid longer, seated on the ground nearly half an hour, and after some time I felt a great pressure on my forehead, like when the blood pressure rises very much. And after getting out of the pyramid I was very, very tired, I think it was too much!
So, it works and the effects are quite obvious. I attach a picture. The material was wooden plates made of pressed wooden chunks, commonly used in construction works.
Best,
Spacetrax
MeggerMan
Hi Pyraman,
Have you done any more tests on your pyramid?
To calculate the power output from your pyramid you need to wrap a plastic tube around the copper pipe and pump this around and into a large reservoir tank with say 1 litre of water, then measure the temperature rise over time to calculate the Joules of energy required to heat the water.
I do not know if extracting heat away will effect the operation of the setup, certainly the plastic tubing may dull the accoustics.
You could trickle water over the pipe into your collector using a small pump or a bucket with a small hole in it and fill it using a plastic jug.
4,186 Joules to raise the temperature of 1kg of water by one degree C
1Ltr = 1Kg of water
So if you can heat 1 L of water from 20C to 50C then you have done 30C x 1L x 4186 J = 125580 Joules
If you plot time against temperature we can work out the power in watts too.
1 Watt = 1 Joule per second.
So if you raise 20C to 50C in 600 seconds (10 minutes) then 125580 J / 600 Secs = 209 watts
If you want to be really accurate you need to put your containers in polystyrene insulated containers.
Rob
olivier
 Hello  Pyraman !
Thanks for your posts.
I build two resonators, but I donââ,¬â,,¢t know where I have to put them in the pyramid because the section of the giza pyramid does not correspond (from mine viewpoint) with your picture that you posted. The horizontal red lineââ,¬â,,¢s are on the heights of the the kings and queens chambers. And the resonators they connect the two red lineââ,¬â,,¢s but it does not correspond with your picture that you took of your pyramid.
Can you help me out? I already have the pyramid and the rest, i only need some good dimensions. And are the copper tubeââ,¬â,,¢s connected in the center of the resonators?
Thanks,
Olivier
olivier
Here are the other pictures
Thanks,
Olivier
