Tri-Force Magnets - Finally shown to be OU?
Started by couldbe, February 20, 2008, 08:45:25 AM
sm0ky2
@ OMNI,
Clanzer's latest vides have demonstrated that there is enough excess energy during the Transition Phase (after initial repulsion< -> before final repulsion) to overcome the initial repulsion of another independent, identicle gate. We are currently examining several possible ways of harnessing this power, and utilizing it. This opens a whole other realm of possibilities, and things to experiment with.
Omnibus
Quote from: sm0ky2 on March 03, 2008, 03:07:03 PM
@ OMNI,
Notice, I don't doubt that excess energy is produced. This I've proven beyond any doubt for such types of devices. Unfortunately, it is yet to be seen how that initial barrier in question is to be overcome so that the excess energy which undoubtedly is produced can be harnessed to build a magnetic motor. @CLaNZeR's last videos are a good step in this direction but the main problem remains--overcoming that nasty initial barrier. Overcoming that barrier is the jist of the problem in all constructions studied so far.
Omnibus
@klicUK's videos should be mentioned as well because they demonstrate a very good systematic approach in studying this design. Especially important is his finding of the shielding effect. Unfortunately, he used the shielding so far only at the follow up barrier. Now it has to be studied for the culprit--that barrier that prevents the rotor to complete the full turn.
Rusty_Springs
Hi All
The point must be made that you can not remove the repel nor can you remove the attract you can only divert it to give you the best result for what you need to do, people talk about attracting in so I showed you how to attractin and still have enoth energy to break the attract back section leaving the gate, to get the most energy leaving then use the way I join the gates, as I said this increases the force leaving as you add a gate, well it shows it does upto the 6 gates I used I don't know how much further you can go and keep increasing the leaving force that I would like to see and Clanzer is the only one I have seen that has the magnets to test this, it would be interesting to see if my setup keeps increase over 32 joins.
For a setup like Clanzer's had I wouldn't be using my Trigate but trying my Corner gate which was made for circler motion, this will attract in and repel out with more force then the Trigate infact the Corner gate is the closest to a perfect gate I have seen, in other words if you want a train type system use my Trigate joined the way I have them joined, if you want a rotating system try my Corner gate but remember everything is a trade off you can't take attract back or repel in away you can only divert them to give you the best result for what you need.
Take Care all
Graham
Omnibus
Quote from: Rusty_Springs on March 03, 2008, 04:47:45 PM
Hi All
Take Care all
Graham
Again, if no way is found to overcome the initial barrier no success in building a magnetic motor can be claimed (not to be forgotten that violation of CoE has already been proved beyond any doubt). The rest is trivial.
