Tri-Force Magnets - Finally shown to be OU?
Started by couldbe, February 20, 2008, 08:45:25 AM
FreeEnergy
it's not like i'm putting a gun to your head and demanding results.
aside from that any more news on this tri-force magnet anyone? any more improvements?
Omnibus
@tinu,
Now, take the position of a devil's advocate and explain why your experiment is not in violation of CoE.
SeanTheLight
I have the geomag toys from wally world, and a circular wood board, just not sure how to arrange the "tri's", specifically the orientation of fields prior to attaching to iron. Also not sure how to arrange a good axle in middle of board for testing. Once i have an axle, i plan on testing some magnet idea's I've had on the back burner.
gwhy!
Quote from: FreeEnergy on March 26, 2008, 01:49:56 PM
I'm still playing  ::) , there seems to be a very small sweet spot in the air gap ( which can be much bigger ) where the roller mag can be rotated 360 degrees ( if the arrays are pointing the same way ) or 180 degrees if array polarity's are alternating to give a bit more unffff through the air gap if a can work out a good way of timing it without losing to much momentum, or I'm also looking at using just one side of a trigate array on a stacked rotor  ( 2 high ) with opposite polarity on the top to the bottom of the rotor,,, it a possibility and something to try  :-\ , its all good clean fun anyway  ;)
Rusty_Springs
Hi All
I just wanted to say I could do the same experiment as the one we seen with the SMOT using to Trigates and having them both on a level plan, the top Trigate would kick the magnet from B to C and then it would drop into the bottom Trigate which would kick it to A but I would still have the problem of bring it back up to B to start the process again, I have shown how you can bring a steelball straight up against gravity so its not hard to move a steelball from A to B but then you have the problem of having it release so it travels from B to C again.
I have found  once I bypass one problem I meet another, making a magnetic gate that attracts in and repels out I find easy and I have shown two that I have made, I found moving metal against gravity is easy and again I have shown videos that prove this also making magnets spin using permanent magnets is easy and again I have shown how this can be done but to me none of it is OU because I can't make any of them spin continusly.
To me and argument about whats OU and whats not is pointless until you have what ever system doing continus movment so it can do usefull work and as of now I havn't seen anything do that be it Trigate, SMOT or anything else.
Thats my 2 cents worth Take Care All
Graham
