Where can we get a computer to adjust timing/fuel mixture
Started by bubblemonkey2, February 23, 2008, 01:07:00 AM
ashtweth_nihilisti
Guys Try the advice mentioned in this document also.
http://www.panaceauniversity.org/Chapter10.pdf
Have a look for the LSU-4 Sensor
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.geocities.com/glorybangla/cqtes.htm
rayco
Hi All
Check out the Holly Commander 950 system. They sell the computer separately.
I use it in my Motor home. you can set and forget or use a laptop wile you drive like I do.
Before you just mess with the timing you need to understand the Flame front of differant fuel types.
With gasoline, Leaner burns slower. so advance the timing
At 65 MPH my 454 runs 15.7 to 1 AF ratio  50 BTDC. as soon as the map sensor senses a load (hill or lead foot) the A/F ratio starts to drop ( run richer ) so the timing will drop also.
I have a knock sensor so I know if I am pushing the timing to much.
ALSO  GM and Toyota said the Fuel Cell cars will not work for them and they are going with Battery's.
So say goodbye to the IC engine in a few years.
Thanks, Rayco
