Robert C. Beck Biological Electrification Device
Started by Rosphere, February 27, 2008, 03:45:33 PM
Rosphere
I recently built a Robert C. Beck Biological Electrification Device.
Here are two hours of the man himself, speaking about this device, and others:
Click here.
My good friend from across the Atlantic, Roberto, asked if I would share my build experience.  I could not find any, "Health Matters," category here in this forum, so I decided to start this new topic here in this category.
The schematic and directions are on page 7 of 42 in the attached PDF; (between pages 4 and 5 of the numbered pages if you print the document.)
I made several substitutions, due to a lack of immediate availability, and yet the final unit seems to perform as intended.  The substitutions are:
1.  Radio Shack TLO82 Dual BiFET OP Amp, (Supply voltage = 36 VDC,) for US$1.99.  Since my supply voltage is only 27 VDC, I decided that this might work instead of the, "LM358... 50 volt peak to peak...," called for in the circuit description.  I opted not to drive 25 miles away to purchase an NTE928M, for US$3.50, which is supposed to be more similar to the LM358 than what I purchased close to home for less money.
2.  Radio Shack INT4742A 12-Volt Zener Diodes, (US$1.39,) instead of the 18 V diodes called for in the circuit description.  Since this diode pair is seldom used, only by the power indicator circuit, I decided to solder in these twelve volt twins instead.
3.  A ceramic 0.22 MF cap that I already had on hand instead of the 22 MF cap called for in the circuit description.  Since this cap is seldom used, only by the power indicator circuit, and I can see the LED light, (a bit dimly), I decided to solder it in for now.
4.  Radio Shack 100k-Ohm Linear-Taper Potentiometer, sans the built-in SPST switch called for in the circuit description.  So, I had to add the extra surface mount switch.  I used two pins of a small surplus DPDT switch that I already had on hand from a box of "mystery parts" that I purchased 25 miles away and last year.
5.  Stainless steel fork tines instead of stainless steel welding rods.  Since soldering stainless steel was troubling for me, I found that the shape of the fork tines fit nicely into some standard female blade terminals.
I had a few parts on hand but still managed to part with $36.00 at Radio Shack.
I have not used it, 'as prescribed,' thus far.  There are other parts of the protocol missing and some strong precautions to heed.  I need to listen to the old man one more time and take more solid notes.
Sorry about the fuzzy photos.  I used a camera phone at perhaps too close to focus well.  However, the circuit, the source with all the tiny details, and all of my substitutions are attached or noted here.
Made possible by Tao and Jason.
More later.
Rosphere
tao
I bought a pre-made device from SOTA some years back...
Beck's device works, period. Its based on EXPERIMENTAL RESULTS...
Here is a GREAT writeup on Beck http://www.sharinghealth.com/researchers/beck.html
You know what is funny? Did you know that Bob Beck is FRONT row in Peter Lindemann's Free Energy Secrets of Cold Electricity video? It is him all right, so you know that Lindemann knows Beck's work very well...
I have used the device many times when sick, and no matter the illness, it alleviates it very quickly...
That sharinghealth.com website has Beck's original paper handouts for sale, the ones that he used to give out for FREE to visitors to his FREE SEMINARS. He wanted NOTHING more than to HELP HUMANITY via this device, period.
Oh, and rosphere, you should be able to get some nice electrodes from SOTA, I know that they used to sell replacement ones. Mine that came with my device are nice, cylindrical and gold plated with a speaker jack connection on the end of the wires.
Peace guys, these will be my only comments on this device.
Rosphere
@Tao,
Thank you.
Who directed this to Jason, I wonder.  ;)
helmut
Rosphere
Thank you, helmut.
Here is a link to the earlier device patent referred to in the video for treating blood outside the body.
Click here.
