The secret of a working perpetual motion gravity powered device
Started by gurangax, February 28, 2008, 12:33:16 AM
AhuraMazda
Many of us had a working theory and when we built it we noticed our own mistakes.
You either have something working or you have not.
If you have, spread your findings quickly and stealthly as fast as you can and make sure your information is complete.
If your information is incomplete then you will be thought of as a scam and we spot them now pretty quickly.
You will come to more money than you can imagine and not from a person or a web site.
AM
NerzhDishual
Hi Gurangax ,
Quote from: gurangax on February 28, 2008, 12:33:16 AM
I found it at about 12 a.m 24th.08.2008, that's about 3 days ago.
What do you exactly  mean? Location date, hour?
Could you be more precise? 08 2008 ?
As your claim is very unusual and as you seem to point out an accurate time/date, it deserves and suggests unusual  investigations : Hourly astrology for example.
Best
Nolite mittere margaritas ante porcos.
gurangax
Greetings to all.
Thanks to some emails now I can see things clearer. I'm not concerned anymore about the prize money. It means nothing. But like I told you guys in the previous post I don't like to give the answer directly. You must think before I give you my answer.
I attached here the uncomplete piece of the thing. then I would like interested guys to tell me what's the problem with it and try to figure out what is the equilibrium position for the weights and wheel gonna be. Give some feedback. And I will respond in not more than 3 days.
So here goes nothing
hansvonlieven
Quote from: gurangax on February 28, 2008, 11:57:49 PM
Greetings to all.
You have a lot to learn my boy !
Hans von Lieven
hartiberlin
How do you remove the counter acting weight and
put it in higher again ?
QuoteSO do you see any method here to remove the weights away from the countering zone?
Well, the only thing I know is to CONSERVE the energy of the downmotion
ofthe weights inside springs and thus shift the lever arms to one
side of the wheel, so the wheel is rotating and
then retract the weights via the spring and begin the next cycle again.
This way you can earn gravitational energy without the weights ever go down.
The potential energy  is stored inside the springs and when
they pull the weights back you can move the weights again there,
where you need them to start a new cycle to shift the leverage to
unbalance the wheel again.
But this process needs very synchronized motion of the weights
and the springs and the right wheel RPM
or you need to use locks for the springs,
so they compress and expand at the right moments, so you
need a mechnical control for it, which is not easy to build.
Regards, Stefan.
