The secret of a working perpetual motion gravity powered device
Started by gurangax, February 28, 2008, 12:33:16 AM
Scorpile
It sounds promising to me, cause the ball in the outer diameter should offer more torque than rotating the chain to pull up the weight in the inner diameter, plus transfering the weight to that inner circle at that point.
I should add, that you could use a ramp of magnets at bottom in repulsion with the weight to help the center lift up the weight with less torque.
Well... for me it sounds good and maybe could work... you don't need 4 months to build this, just use wood and you'll have your basig setup probably in 2 days.  It should show you if your idea is possible or not, before building a better one.
sanarunnow
I also think this will work... nice invention there gurangax. :)
Nothing is impossible - Christopher Reeve
gurangax
Greetings perpetual seekers
Just to inform you guys that my previous design doesn't work. To be specific, the top weight will not have enough torque to lift the weight at the bottom right. The weight on the bottom left was enough to lift the weight at the top though. And after a month of doing nothing, I finally get my hands on this field again and I found some interesting approach as how to move the weight at the top to the left side. It is still new to me thanks to some pages in this forum which leads me to the MT drawings.
I can post it here if you guys are interested.
-regards-
Charles
