Complete information on working SM style device.
Started by spherics, March 17, 2008, 12:03:53 AM
tao
Here is a device that appears to also use the 'shaping of the aether' as its mechanism to produce energy output...
I am not saying it does the same thing, I am merely posting this image to show some 'potential evidence' that modulating the aether can be used to produce an energy output...
Take it for whatever it is worth to you...
konduct
Thanks Chris.  So is He saying to just physically locate the 3 coils 120 degrees apart and fire at the same time? Or does he mean fire them at separate times?
chrisC
Quote from: konduct on March 17, 2008, 02:49:47 AM
He meant 120 degree electrical phase shifted and NOT a physical spacing. (If you're familiar with a oscilloscope, you can see how signals can be phase shifted when they are designed accordingly).
cheers
chrisC
konduct
So what is a degree in terms of frequency / amplitude?  I understand the purpose of the phasing is to create a rotating magnetic field which I get...but what is meant by degrees?  Where the peak shows up or a frequency that is in thirds?
I'm reading up on this as I go back and forth here.  I also have a dual oscillator synthesizer that has many waveforms available and additional LFO's built in...thinking I could pump the right notes through an amplifier and play with one of these setups. I also understand acoustical phasing pretty well...
So is it basically when you get to 360 degrees, you are actually back in 0 degrees phase?
konduct
Okay...I think I get it...fire each coil at different times exactly 120 degrees with respect to the original frequency?  The 120 actually determines the firing "timing"...a four cylinder engine fires 90 degrees as an analogy right?
