Steven Mark´s associate Jack Durban comes forward with more info !
Started by zapnic, March 17, 2008, 04:28:58 AM
turbo
Quote from: CTG Labs on March 20, 2008, 08:23:15 AM
Way to go Marco!  Are we back on the trail!
We are  ;D
Edit,
Here is a close up of the first filter.
Below is the chokes in Stevens coil.
Also note that when he tries to measure the ampreage with the yellow claw amp ,he first tries to measure the current running thrue the chokes.....why? because he knows it is part of the output circuit.
M.
wattsup
@Earl
First thing, when you post something, could you please not remove the Re: in the subject field as this creates confusion on the main posts list.No Re indicates the "start" of a new thread. I don't know why you do this.
OK, if you look carefully at the center two toroids (chokes) you will notice the windings are using finer wire and also much more windings then you would see in a standard choke that has heavy gauge wire and much less windings. I have tried to see on the market about this with no luck.
Now if they were used as chokes and if the device is to follow anything by Tesla, it would have to be a high-inductance and this may explain why there are much more windings. With the high inductance, this will assure the charging of the yellow caps. Since the TPU would have to initiate an interplay of energy inside the coils, you require a charge/discharge ability that a high inductance coil would offer.
I am not sure if the coils you have shown have this ability given the thickness of the wires and low number of turns.
@marco
Your post of photos was just in time. Thanks.
Mannix
 have just heard the whole of Jacks interview
The inspiration that he  offers is commendable
Thanks to those who were on deck
He may have been involved at an earlier stage but not to the degree that we were led to believe
Steven might have said that he was trying to take his technology...which was confirmed
He was not aware of this forum so he should be commended for what he offered.
I cant see how media exposure will assist the cause but it took courage to do so
there are at leasr 20 other people with a story to tell....come on guys!
I did not agree with his assassination of steven and still dont see the purpose for it.
Steven is certainly not "cashier" category which makes me question his ability..
Of course some info that I provided may be out of context....time (and effort)will tell
Im sure that he may offer  some assistance once he gets up to speed with whats been  happening here
Check out Roberto!...he has it singing
Nice Clean supply Marco!..it will be handy as far as I know
Yes It important that lots of people do this and not just write..if that's  sneaky...then Im perplexed by that judgment. No one person should have this.
Brian Collins died trying to get this alive with investment. and if it wasnt for him I would never have herd of this etc....etc...go figure
Can we let Jack take his thread back and move foward here ?
Lindsay
turbo
Quote from: wattsup on March 20, 2008, 09:07:39 AM
@Earl
@marco
Hello Wattsup,  :)
The capacitors store the unwanted harmonics and then they fire them back into the choke to cancel them out.
This is only a means to get to a clean DC output and as you can see i have used 3 of these isolating circuits in my supply.
I use 3 diffrent cap/choke combos (fine wire/thick wire etc.) for diffrent harmonic target.
I can tell you the output still isn't what i want it to be.
But this does tell me something about the output of Stevens coil with all the hash since he seems to use only one noise isolating circuit.
M.
wattsup
@marco
In the world of OU, there is no such thing as unwanted harmonics if it means to stifle energy creation. This cannot be for such a purpose. I know you are using it for that reason or purpose in your supply, but this is not the same thing at all. Why would you want to remove harmonics when they are the very essence of the havoc you attempt to create inside the coils.
If you had a bridge rectifier inside the black box before the true output, and all you are running in the demo is light bulbs or a drill, who cares about the harmonics. Also, the TV was lit through his converter that would have taken care of all that already, so I do not think this was used for that reason. Also the two black capacitors are connected in "series" and are probably used to smooth the output.
There has to be another reason for those chokes.
