Steven Mark´s associate Jack Durban comes forward with more info !
Started by zapnic, March 17, 2008, 04:28:58 AM
0 Members and 25 Guests are viewing this topic.
Motorcoach1
 It's been a while but I can say this I invented the home theater speaker system , thats a fact and i can prove it. so that said moving on. If I remember correctly the company Spherics was trying to perpetrate a fraud in it's sound system. Carver amplifiers sent a cease and dissist order to them not to use their technology of the digital delay circuit they so coveted. when this happened they still tryed to pull off the sound system and got sueed, but not by Carver.  As far as Mr Durban goes he just had a contract to SM and did his part , I hope he wasn't in it for other reasons.  so enought said move on
turbo
Hi Guy's  :)
Jack said yesterday he'd take a break this weekend to locate the video.
I don't blame him for not comming here.... this place looks like a battlefield.
M.
MeggerMan
@Jason,
RMF
Read your bit about rotating magnetic fields.
Have a look at this article about 2 phase and 3 phase rotating magnetic fields:
http://www.tpub.com/neets/book5/18a.htm
http://www.tpub.com/neets/book5/18b.htm
It shows that to create a rotating field you need a 2 phase or 3 phase supply.
So for 2 phase you need 4 coils and for 3 phase 6 coils (so its phase x 2 = number of coils).
We know that there are 4 coils so it makes sense that the input should be 2 phase.
The AD9959 can handle 4 phase so we could make a finely stepped rotating field with 8 coils.
Only bit I'm not sure on is if you can get current flow in a copper coil running around the inside of the stator field.
The reference you refered to was for a plasma.
The outputs from a flip-flop being feed by a signal gen. will provide a kind of 2 phase but it has no direction because it is not sinusoidal.
Go to three pulses and you have direction but you now need 6 control coils to get your rotating field or 3 coils if you don't need to pair them up as is required in a 3 phase motor.
The TPUs people have shown so far have control coils that follow circumference of the toroid, maybe they should be centre facing or say 45 degrees off centre of the toroid.
Rob
Frederic2k1
Quote from: FatBird on March 22, 2008, 09:52:29 PM
SPARKS posted a Aether Votex Unit Diagram photo about 20 posts back.
I did a search & found a site where they claimed working units:
http://dallastexas.net/PinkyAndTheBrain/archive/
The following is a SAMPLE EXCERPT of 1 of the posts from that URL SITE above.  Does anyone know anything about this?
Here is a summary of the specs of my very crude duplication of Clifford Hazelton's free energy device.  Two aluminum plate 6 inches in diameter and 4.25 inches apart.  Alu plates are horizontal, flat.  The plates are fed with a high voltage coil which puts out about 25 to 30  KV at one watt of power. That is very low power. It takes 15 minutes to charge a 25 KV capacitor bank that can be hooked to the supply.
For this experiment the capacitor bank was not connected. The HV supply has, as part of its construction, a HV fullwave diode bridge recitifier. The output from the bridge is connected directly to the Alu plates using jumper cords from Radio Shak. The HV supply was connected directly from the output of the bridge off the supply to the two plates. Luck would have it that I connected the right terminals to the top and bottom disk.
At this time I don't know whether top was + or minus.  The torroid coil. I made it by taking a piece of 1/2 inch tubing, putting a dowell into it to make it rigid, and wrapped (very sloppy) a bunch of turns. I figure if it would work, sloppy was ok. I pulled the dowell out.  Stuck a 2 inch piece of dowell into one end of the tube/coil and connected the other end into the other end of the coil. Voilla, a crude torroidal coil. Probably 75 turns of #28 wire on coil.  The finished coil is similar to one of those SLINKY coil toys.
I put the coil into the aluminum disk sandwich on the bottom as that seemed to be where the wide end of the vortex would be from Cliff's discussion and the rolling ball experiment. Then connected a 1000 ohm resistor to each lead of the torroid coil using more jumpers. Hooked a voltmeter across the resistor with two more jumper to measure voltage. Actually tried two different loads, 1000 ohms and 165 ohms. Getting about 35 to 55 volts on the 1000 ohm and 70-109 volts on the 165 ohm.
end.
Thank you for that link, Fatbird. I've read thru the topics at that forum and it seemed to me, that they have more than one working devices which have an overunity factor of over 10 !
I hope I understand that right, but at one or two topics they spoke about a ball bearing test. It is to visualize the aether vortex between the two plates. They just put a pachinko ball between the plates and the ball starts to spin up at the edges of the circumferences of the plate.
Cliff mentioned at this part, that this is also the direction of the currents which are induced to the toroid coil by aether vortex.
Some of the forum members mentioned that you had to blow smoke between the capacitator plates, which gets then ionized by the high voltage and "follows the aether's vortex"...
So the spin up comes directly by the vortex and the induced current in the toroid coil stays up as long as the capacitator plates are loaded with high voltage, a sustained E-Field.
At least quiet interesting when I understand that correctly. Possible it is another version of the "Steven Marks TPU".
QuoteSo, at this point, having read about the ball bearing, and thinking of =
an inductive current forming, I envisioned a coil instead... This beat =
Tesla's published view hands down...
Think about it. If you drain the capacitor of charge with a coil, it =
will never fill and come to be &quotan open&quot.
It will keep pulling charge, which you will keep draining...
poynt99
It may not have been helpful for Jack to have disclosed SM's sexual orientation granted, but it's also unproductive to be slamming Jack.
He was not privy to much if any technical details, granted and he admits that, so leave it alone. He was there, and to date there has been no contact with anyone else who has first hand experience with the devices. SO be thankful that there is now contact with a person who has seen the devices with their own eyes. Is that not worth a lot?
Providing Jack is inclined to answer a few questions, and considering the stream of info from all other sources has long been exhausted, any help he is able to provide should be considered invaluable.
If he does come visit ou, what he sees here as negative posts towards him will not be conducive to obtaining further information and better videos. Bite your tongue if you must, and go back and edit your posts accordingly.
