A truly overunity Transformer / Meg
Started by LoganBaker, March 17, 2008, 06:32:56 PM
Kator01
Hi Getca,
no, it is showing wrong values even with sinus-waveform. I had a much better one form ELV. But even this one had a measurement-error of 10 - 15 %. They are al made in China and  have simply wrong software which returns false values of real wattage based on a wrong the phase-shift-angle-calculation. I state here strongly agian not to use these type of devices, but rely only on scope-measurements. I have given you the Kanarev-Link. All is written in there. You have even the advantage to read his papers in original language
Why do I get involved here is simply to avoid that you spent time barking at the wrong tree.
I estimate this configuration as a good concept . . . but please use true measurement-techniques and not incandescent light-bulbs for output-proof, only linear-resistors and voltage-measurement across these resistors
with scope.
Needless to say that JLN-Labs was presenting the biggest failure with his MEG. He used neons. What a blunder.
Kator
Kator01
Hi Getca,
what are you frowning at ?
Kator
Nali2001
Looks like a Full wave bridge rectifier on a heatsink to me.
Only it is used in half wave.
Getca
Quote from: Kator01 on October 31, 2008, 08:31:17 AM
I estimate this configuration as a good concept . . . but please use true measurement-techniques and not incandescent light-bulbs for output-proof, only linear-resistors and voltage-measurement across these resistors with scope.
Hello Kator...Why not lamp-bulbs? It's just non-linear load. What's the problem. Yes, I used something linear-resistors, but I couldn't see a diference. The MEG device was working correctly. Don't forget the MEG isn't a transformer and can work with output short circuit without input current rising. You are right about the scope, but Ivanov's measurement is correct and it's true. If You don't believe ask Altium. Well, how do I understand this one:
Quote from: Kator01 on October 31, 2008, 08:37:24 AM
Kator
Don't You talk about the Ivanofv's MEG picture? If it's so I have shown a rectifier by a red arrow and if You spend some time thinking, You can get the true about the control coils driving. In my opinion there isn't any kind of switching electronics.
Regards...
Rossen
nievesoliveras
Hi!
@nali2001
I saw the video and it raised several questions in my mind.
1. Is the transistor showed on the graphic PNP or NPN?
2. The capacitor is 1uf, but what is the voltage?
3. The diode is germanium or 1n4007?
4. How many turns are on the coil?
Jesus
