HHO ON DEMAND BY PERENDEV
Started by Eden, March 18, 2008, 12:25:32 PM
FosterVS
Awesome! I have built the watercell
device from
http://www.overunity.com/hho.htm
(coils of stainless wire on a plexi core, very low output) as well as one I made from stainless wallplates (good output, but high current draw i.e. 15amps@12VDC).
Have you measured the current draw on the device? I have seen other devices with a center negative plate, two outer positive plates and the rest are disconnected i.e. neutral. I wonder if the hydrogen production would be similar with less current draw. Also, I missed mention of what you are using for electrolyte.
vdubdipr
hey dallas, remember the you tube video hydrogen tony? where you asked the psi rating of my cell?
well if you havent checked back on it, it is rated for 135 psi, although i only got it to 27 psi before i got bored.  keep it up...
as far as the prendev video..........lame... just seems like some jackas with alot of money and no intellegence,  are you guys sure its the same guy with the magnet motor???????
thats just what i think...
Ioku
So I built one of Dallas vortex cells, found the cups at walmart, I built one using 7 cups and have it in my car. I'm just using distiled water right now so HHO production is low, still waiting for my koh to get here. once it gets here I'll try and do a lpm test and see how efficient it is.
FosterVS
Quote from: Ioku on April 18, 2008, 06:06:48 PM
Couldn't find these cups at Walmart here in Canada, however I was able to locate them at a chain called "Superstore". These ones are pretty thin metal.
I have one installed in my vehicle, using distilled water and baking soda as electrolyte. However, it is really sucking the current - started with a 20A fuse, which it blew almost immediately. Even a 30A fuse blew fairly quick. Going to have to use a larger scale fuse, and higher current rating, or switch to a circuit breaker.
Ioku
From what I have read you have to get the mix of electrolyte down enough so you don't pull so many amps, I also read that baking soda is not so good because it can cause a coating to form on the electrodes, thats why I am still waiting on the KOH, and has anyone here bought KOH from biodiesel barn I ordered some about 2 weeks ago and it is still not here.
