AETHER VORTEX TPU
Started by FatBird, March 25, 2008, 07:21:53 AM
vince
I gave up on the high voltage TPU!  I tried all kinds of different things, including different coils but got nothing out of it.
I'm working on a combination "Thane Hiens" magnetic coupling drive motor /rotating magnetic field toroid that I have been thinking about.
I'll post it when I get some time to put it together.
Vince
FatBird
Cliff said the output kept going even after he disconnected the HV.
FatBird
Please check Patent #   4,897,592.  I tried to upload it to this post, but it was refused due to it being over 50 KB.  If someone can post the Patent, please do so.
http://Pat2PDF.Org   is a really nice place to search for patents.
It looks like said patent has a lot of similarities to the TPU described in this thread.
Comments welcome.
FatBird
This is interesting from:
http://dallastexas.net/PinkyAndTheBrain/archive/00000063.htm
The applied loading on the stressed system is through the output coil. This coil does not load the plate charge, ie: the electric field. It loads the vortexing magnetic field which is perpendicular to the static field. That is how the plates maintain their charge - the charge is used to create the
conditions for the vortex to form, it is the magnetic vortex that is loaded, not the E field between the plates.
By loading the vortex, as it is trying to make a 'connection' between the two charged plates, the capacitor dielectric (vacuum) is held in a constant state of imbalance and therefore the capacitor is maintained in a constant state of charge. It's that simple!
Cliff tells me that the tornado between the plates is not something you have to create - it happens naturally in a charging capacitor. The trick is to apply a load to this tornado and watch nature compensate by increasing power to the vortex to overcome that applied load. Beautifully simple.
FatBird
Right Jim, that is what Cliff said.
