Gravity Magnetic Motor
Started by TheOne, March 29, 2008, 12:33:58 PM
AB Hammer
Hi gwhy!
I am in the proses of looking for a few good size magnets for the wheel I have built. I have concentrated on gravity wheels so I have not been stocking up on magnets for a larger wheel. But when I get them the wheel will be done and as long as my calculations are correct it should be able to run at least a bicycle generator. But I do hope for better. As for making your oval shape. Let me think ..... Ok I think I got it for you. 2 magnets, one on each side of your tri-gate, this should give a mild tug (due to the overall change of the field) on each side for your oval to possibility work. Don't put them to close but just enough for the tug. You may also have to make one a little higher to keep a single direction on your oval. I played with magnets when I was younger back in 1974 and built a magnet wheel that ran for 1 and 1/2 days before it wore out the center of the cardboard. The funny thing is I didn't think much of it until last year.
Good luck
PS. How I got it to run in 1974 was, each magnet was adjusted individually to make the field do what I wanted it to do, and it was not a uniformed design. Uniform designs make uniform fields and that is the best suggestion I can give for a basic magnet wheel.
Alan
Omega_0
Quote from: gwhy! on July 01, 2008, 05:17:09 PM
a roller mag entering and exiting the array on the same plane is a non-starter
Did you use an inclined plane or was it horizontal ?
If you are sure about repulsion being less if the roller enters from the top (90 deg to the plane of tri gate array), then it can be accomplished. I'll do another animation to show how.
But I guess the advantage will be nullified by the cost of lifting the roller up to that height.
Shields cause problems because they distort the field, so the roller may not move at all. But I never tried so can't say for sure.
gwhy!
Quote from: Omega_0 on July 02, 2008, 06:06:29 AM
Hi Omega_0,
  I had a more or less the exact same setup as in your model on a incline. There is a sweet spot on the entrance/exit of a array no push or pull and I think like you have said :
All the best.
itsblockdog
of the subject above... "orbit"....in my humble opinion: oval vs triangel.... oval like a comet in travel (natural)
Quote from: gwhy! on July 01, 2008, 06:01:00 PM
Hi AB,
   I have done some tests with a tri-gate setup as in the picture I post in this thread not 100% setup as in the picture but same principle only using 1 pair of arrays. The test i have is a wind down test now to be honest it wasn't done very accurately it was done with a watch with a second hand and a hand spin with and without the tri-gates in place. But it was very promising there was a good 10-20 secs more spinning with the arrays in place and this was consistent until the arrays were slightly out of the sweet spot. The problem with me I really like building side of things and get very impatient when I only have 1 build on the go at any one time, and at this moment I have another 3 builds on the go so I tend to flit between them as and when I can. And now the hold up on the design shown in this tread is the fact that I would like to get more of a oval movement from the pendulum instead of more of a triangular movement. So any suggestions are most welcome  :P..
All things are possible
AB Hammer
Alan
