Hidding in plain sight
Started by vincent68, March 31, 2008, 03:51:15 PM
prometei
cool
anybody know of any simple circuit, with a relay maybe, that will check the voltage of the recharging batteries say every minute, and when it gets to a specific voltage, 1,6 V or so, the circuit will turn off the charger? I'd like to hook one of these up to my bedini charger :)
?Education is a system of forced ignorance.?
unknown
"Any sufficiently advanced technology is indistinguishable from magic."
Arthur C. Clarke
"It is through science that we prove, but through intuition that we discover."
H. Poincare
Koen1
Yeah, that's a nice idea...
If you manage to recharge simple "non-rechargable" AA or 9V batteries
using a Bedini charger, that would be cool :)
Would a relatively simple setup of a voltage sensor and a switch (transistor) work?
On a different note, did you guys know that the 9V "block" batteries are
actually 6 small cylindrical cells wired in series? Or at least, the alkaline
"non rechargable" ones are. I have opened up several different brands and
they were all the same: 6 thin zinc cylinders with a carbon filling and a
goopy sludge in between, the electrode on the carbon a simple metal
nail of about 3 to 4 mm long, isolated from the zinc by a thin layer of plastic.
It's similar to some large 12V battery blocks, as some brands appear to
fill those with a number of standard AA sized batteries in series...
Back in school they taught me that block batteries are the only ones
that actually contain a row of dissimilar metal plates in an electrolyte solution,
which was the reason why they put out a higher voltage. Although wiring
6 or more cylindrical batteries in series does effectively give a similar setup,
I do feel a little bit cheated by the battery manufacturers... ;)
Sprocket
Quote from: MeggerMan on April 10, 2008, 08:11:43 AM
@Sprocket,
Maybe you could charge them at a lower voltage or current using two pieces of foil, piece of card, crock clips and a resistor or variable resistor of say 1K. Make a sandwich of foil - card - foil and place this between the +ve terminal and the charger connection.  Then use crock clips/paper clips to bridge a resistor across the foil pieces.
The batteries are not designed to vent gas so I guess its the gas from fast charging that is forcing a leak of potassium hydroxide gell to occur.
I was wondering if slower charging will create less leaked cells.
Rob
I actually have a bench power supply that allow accurate setting of both voltage and current, so using that would be easier.  Thing is, I have only 1 non-leaky alkaline battery left, so I will have to try and hunt down some more before I can continue experimenting :)
twosox
you can buy a 'proper' charger for alkaline batteries, the one below is about ?25 (one of the
more expensive ones) but they can be quite cheap. they've been out for a few years.
heres a snippet from the website :-
The EverCharge Multi-Function Multi-Chemistry Universal Battery Charger represents the latest innovation in battery charging technology. Not only does the EverCharge perform quick charging capabilities to Ni-Cad, Ni-MH, and RAM batteries, but it also can safely recharge previously non-rechargeable Alkaline batteries.
The ability to recharge Alkaline batteries will not only save you money, but it can go a long way to helping the environment at the same time. With over an estimated 30,000 tonnes of used batteries, classified as hazardous waste, being deposited into our landfill sites every year in the UK alone, the EverCharge is an important Eco-Friendly product.
Recharging of Alkaline batteries is dependent on the quality of the battery but tests show that the alkaline batteries can be recharged up to 85%-90% of their original capacity up to 15 recharges and costs literally pennies to recharge. This makes the cost of your standard batteries almost a steal.
pese
i have selled and used years ago the ray-o vac
batteries and the orinally charger (because "other" chargers can let explode or "leak" the batteries.
i used this to have 1,5 volts instead 1,2 volts (cad).
After this i have used low cost cahrgers  (5-10 $) with cahnge in the circuit, this way that battiey can not charge higher than 1,9 volts.
take some knowleges also here  .
(clic to "CACHE" )
http://www.google.de/search?hl=de&q=ray+o+vac+alkaline+charger&meta=
Pese
