can any of you answer this?
Started by redriderno22, April 07, 2008, 09:23:09 PM
z.monkey
Howdy,
All these different forms of energy are just that, energy.  It is the frequency of the energy that makes the effect which we can sense.  DC voltage is at the bottom of the spectrum oscillating at 0 Hertz.  Your brain oscillates at several frequencies all below 10 Hertz, it is energetic.  Alternating current power is electron flows oscillating at 60 Hertz.  Aircraft power oscillates at 400 Hertz.  Radio waves manifest as energy from 9 Kilohertz to 100 Gigahertz.  Gravity is energy around 1 Terahertz.  Light manifests as energy around  1 Petahertz.  X-rays are energy around 1 Exahertz.  Gamma Rays are energy are around 10 Exahertz.  Gamma rays, x-rays, light, gravity, radio, AC power, thought and DC power are all forms of energy manifesting in different ways because they are different frequencies.
Particle physics is what you are looking for.  You want to be able to see the way electrons move and interact with the ethers.  This can be done, but you can't use your eyes.  You have to use your mind to "see" subatomic particles interact.  Like the way the odd shaped electrons move through the etheric "sea" and leave a wake in their path.  Electrons sort of look like an ice cream cone.  The leading edge is a spiraled cone, each one unique.  The trailing edge is a half sphere.  When they are pushed through the ethers they spin because of the spiraled cone on the front.  They leave a cone shaped wake in the ethers in their path.
Be careful with this information, you'll shoot your eye out, kid!
Blessed Be Brother...
Goodwill to All, for All is One!
zerotensor
Electrons are tiny black holes with toroidal event horizons.
They do not decay, because the geodesics on the horizon are closed loops that thread the aperture.  The equations of GR insist that these loops remain closed.
"Spin" is the combination of toroidal and poloidal momenta in toroidal spacetime.
Spin twists-up the geometry of spacetime outside the horizon.  This "twist", or "helicity", is the electromagnetic field.  Specifically, the helicity of spacetime at some point is identified with the magnetic vector potential there.
From an accelerated reference frame, the twisted spacetime behind the electron appears distorted in a regular way.  The distortion is a regular wave pattern with a wavelength that is inversely proportional to the magnitude of the acceleration.  This is a picture of an electron being accelerated by a wave-train of light.  (or, equivalently, an electron radiating a train of photons as it accelerates in an external electric field).  From an inertial frame, the light appears to move at velocity c.
So there you have it.  Electrons are little knots in space which twist up the space in their neighborhood, and light is the regular wave pattern in the helical spacetime that results when an electron is accelerated.  All described using general relativity, so there's your gravity connection.
erickdt
Quote from: redriderno22 on April 08, 2008, 11:08:57 PM
could gravity be a form of voltage?
No, gravity is a gulf in spacetime.
WilbyInebriated
"Gravity is not an intrinsic property of matter, neither is inertia. These secondary forces are both formed by the reaction of matter to the dynamic field of SuperLight. Gravity is not an attraction! It is the result of a universal pressure, exerted by SuperLight as it rains in from infinity, from all directions, onto every object.   Materials are not 100% transparent to SuperLight. I estimate, perhaps about 99.99999999% transparent. As a consequence, all material domains, all "matter", experiences an acceleration caused by SuperLight. Every "particle" is affected by a slight drag, or pressure differential, as SuperLight travels past and through them." -- dr. john v. milewski
more here...
http://www.hbci.com/~wenonah/new/milewski.htm
erickdt
Quote from: WilbyInebriated on April 09, 2008, 04:39:10 PM
more here...
Huh? Relativity (what I described) is proven.
Superlight? Never heard of it before...
