The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
sparks
    @Pauldude
     I don't know if you pickedup on the information supplied by Spherics.  (I believe this was SM giving his disciples a little lecture ::)   What was most important in his postings were that if you pulse a piece of copper wire that is run in parallel (physically and electrically) with a piece of iron wire that there will be an acceleration of the magnetic field in the direction you want.  The kick pulse when applied to this parallel or bifilar arrangement causes the copper to create a magnetic field change first.  While this is happening the kick pulse is causing the iron wire to rearrange it's atomic lattice and then the resultant magnetic field response to the kick.  The reaction of the two different metals to the same spike (or spark) causes a magnetic field shift at great speed and in a predictable direction.  When this bifilar arrangement is wound into a solenoid coil and a collector piece of copper is placed within it's interior this collector winding experiences this magnetic field shift.
    In later designs sm came to the realizaton that the iron wire could be replaced by a copper winding that is pulsed at a lagging frequency to get the same effect as the timed iron/copper response to a single pulse.  This makes the tpu a dragless dynamo.  The backemf of the copper collector winding not dragging down the prime mover because we moved the magnetic field across the copper electrically not physically.
   @Mannix
    This would be a good time to deny or support a speculation on the dynamics of the tpu and Stevens work.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
pauldude000
@Sparks
Ion wire has a differnt conductivy than copper. Different conductivity means different speed of propogation. DIfferent sped of propogation means lagging or leading pulse at same frequency. ANother form of phasing.
Man, I think I am running a fever. I feel like I am burning up.
Paul ANdrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
sparks
    SM also used this timing effect by pulsing metal in the base of his premier design.  I'm not sure what to call it but it is the one that puts out 800watts.
In this unit he uses two frequencies as one can obviously deduce from the two identical oscillator setups he has in the middle.  The two white transformers are air core torroidal transformers that are used to charge the two identical caps.  When the caps get to a certain voltage they are discharged into the kick windings through a semiconductor avalanche circuit .  They are being fed by a feedback winding sensing the magnetic field shift induced by the respective kick windings.  One for the leading and one for the lagging kick.
   Spherics comes on board in 2008 and tells us that the kick windings should be face postitoned and no iron, but this is not what we see in 98. We see steel in the base of the tpu's being pulsed to stretch out the solenoidal magnetic shift towards some 1/2 ass secondary coil.  Master of Magnetics LOL.  He didn't have the first clue as to how a dragless dynamo should be built and if he was spherics posting still doesnt.  What he did know is that the way to get free energy is to use a kick to act as a catalyst in producing a magnetic field disruption that will yield thousands of times more translatory energy than what is needed to produce the kick.  This guy tried to package one of Tesla's designs that GK is working on right now and pawn it off to some chumps.  Total asshole then and total asshole now.
Think Legacy
Spread the Love
sparks
@Chef
     I see energy as change and antienergy as inertia.  And matter as the combination of both.  So when we change the inertial field around a form of matter potential energy or the potential for change stored in the matter is released.  Pure energy displaces the aetheric inertia and is able to manifest through spacetime and excite the release of potential energy from matter that it encounters.
    If you believe that spinning the aether is the only way to release, use, and store potential energy from matter I guess it's your right.
@all
      I believe anybody with experience with transformers, alternators, dc generators,  or electric motors will see the benefit of effecting a magnetic field change by use of an energy pulse.  The antiquated way of changing the magnetic field around a conductor by physical movement of the conductor through a compressed magnetic field or the use of an iron laminated core to direct a magnetic field compression by resetting magnetic domains of the metal should be a museum piece soon.  The sooner the better.
    In your experiments and designs please remember that the kick that SM credited energy conversion to is the scource of free energy.  The kick can elicit mass conversion to energy without loosing any of it's ability to do it over and over and over.  The spin energy of the Earth itself is the capacitor in this energy circuit.  It is the scource of back emf.  Back electromotive force.  It restores the electrical magnetic resonance of the mass disrupted by the kick.  So simple even and idiot like me can understand it. ;D
Think Legacy
Spread the Love
