The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
0 Members and 23 Guests are viewing this topic.
pauldude000
@all
Like I said before... If you want to use tubes, USE tubes! SM in the videos wasn't so I am not......
@Sparks
If you are silly enough to do what you propose in your "schematic", then you better do some research on X-Ray production, as you may leave a nice picture of your bones on the wall! (I post this for safety)
@Otto
You had better research the same. (concerning X-Rays) Too high of voltage and tubes don't necessarily mix.
@all again
Radio fields and electromagnetic shielding are the least of our worries!
Nobody building TPUS needs to flop like a fish due to electrical shock, die unnecessarily from cancer due to an X-Ray bath, etc., etc., etc.
Be safe people.
In my various hobbies, I HAVE been subject to dangerous levels of electrical shock, and it is NOT fun. I have awakened laying behind a couch, because my arm brushed both a frame ground and the wrong wire at the same time. I have had to check to see if someone needs CPR, because they bumped a primary of a working Oudin coil. (Thank goodness it was a tiny one. Probably only 80 or 90 joules, instead of 600 or 1000....) A man I knew is dying from cancer due to X-ray production because of a laser he was building.
I have designed and built everything from quarter million volt tesla coils, to higher amperage lower voltage oudin coils, to 5000volt much higher amperage D'Arsonval high frequency autotransformers. I have built Van De Graff, and Wimhurst electrostatic machines. ALL OF THEM ARE LETHAL. There is no such thing as SAFE electricity.
Concerning High Frequency Electricity...... this stuff is particularly deadly. Not necessarily from the direct shock, but the induced fields and unwanted particle emission. The person whom thinks otherwise will end up taking a dirt nap sooner or later, just a matter of time.
Consider anything with high voltage lethal, and anything with caps even though battery powered as dangerous. When working with voltages above 110, USE ONE HAND, with the other in your back pocket to keep it completely out of the way.
Safety is no joke, and what we are working with here can be dangerous if not lethal. Assume lethal, to minimize it's danger.
Sorry, but this needs to be stated.
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
pauldude000
@all
Sorry for the lack of posts lately. I have been building and testing. I will post more when I have more relevant ideas, news, or data. At this moment I am VERY busy.
Paul Andrulis
sparks
@Pauldude
      The first thing I did after taking the tv back panel off was to check for a shield around the flyback.
No shield.  It's a small set.  I place a small flurescent there that lights up.  Trying to grab some of the xrays there.  Then I series fed the crt through a small  flurescent and it lights up.  I'm up to about 10 watts cold electricity at this point..  Then I wound a 4 turn bifilar around a 40 watt 18" down placed one end near the flyback and fed the coil on one end from the flyback output,  it lights up between the flyback and the coil pretty darn bright. Now I think I'm up to about 15 watts illumination. Plus the crt and all the other goodies the flyback drives.
    What did I learn from all of this?  High voltage stressed space gets cold. Bulbs are lit but they are colder than the surrounding air. There is plazma inside the flurescents so they should be getting hot.
Cold plazma.  Maybe the aether is a cold plazma and the electric field keeps it dispersed enough so you don't see any temperature rise. There is a shitload of energy in the plazma but it is not relavent to anything until we mess with it's stratification. hmmmm
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
mdmiller
here's an interesting claim from this page:
http://www.chemtrailcentral.com/forum/thread13162.html
...... "I cracked the Steven Mark device and it is to dangerous to give out. Half the homes in the country would have gone up in flames if I had handed that out. I'll crack this one too. If it is the best after I crack Meyers's invention you will see it on the net. So, I'm working on it like I said. "......
Grumpy
If this person had cracked the TPU - he would know how to contain the energy - the field.
        -Frank Edwards
