The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
sparks
   Instead of winding three control windings covering different portions of the tpu od would it work out better to have three windings wound around the whole circumference that are next to each other.  Route the feed from the pass filter so that there is a directional shift of energy with each set of turns representing a pole.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
infringer
If there are interactions with the earths magnetic fields...
Would not the orientation of the coil(s), pulse phases, angle seeing how the earth is slightly tilted..
be a roleplayer in this setup... I never payed close close attention but do they keep the coil facing
in a certain direction during operation? (Kinda why I started the observation collective effort thread)
Why does there appear to be a slight angle on one of the coils in Jack Durbans video release?
Curiousity for me but if the earth interacts with this mochine would it not be a mitagating factor?
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
aleks
Quote from: sparks on April 10, 2008, 09:54:56 PM
Sounds pretty logical. In Tesla's patent we see 4 windings around circumference. I thought that you can actually use any number of them.
aleks
Quote from: pauldude000 on April 10, 2008, 08:42:36 PM
It is already assumed that a mosfet power stage is used (I want to hit the controls with at least half an amp, not the piddly 200ma my 555 can source.). However, a mosfet, or other transistor, will reproduce the signal applied. If you hit it with square waves, it will produce square waves.
Otto's MOSFETs exhibit avalanche performance, so on every square wave attack front they produce a saw-tooth instead, with a gross spike (~400V).
otto
Hello all,
@Aley
youre talking about "old times".
In that times I had nice kicks at the start of each square wave at OK, 400V.
As I hope that Im now a little bit cleverer, Im working with high voltage sine waves. I know that you all know the Tesla patent 381 970. I also was "familiar" with this patent. Then I made a hand drawing of the shown picture to really understand, made a few other drawings......now I wonder why I have to pay for my electricity.
Otto
