The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
Grumpy
Look like you're differentiating.
kick is an oscillation - something you would not expect to see.   A flutter or flurry of activity.
You need more voltage, by the way.  Tesla would start with 10k to 20k - that's gettin' 'r dun...couple few hundred at least.
Kinda like Bob Boyce put it - you push nature and she pushes back - HARD!
        -Frank Edwards
innovation_station
yep she does push......
you all let me know when i can show you spinn or orbit or traped electricty
it has a constant ossolation form round 300vac - 0  vac and lasts for a verry long time from a pluse or 2  ;)
does it rotate? when traped in a coil?
what do you think ...
lol
did i put magnets on a string did they follow or repell  the osc voltage around the ring   lol
of course they did.....
so why does this work ? how long does this effect last ??
well i had electricty traped b4 in all copper coil collector and control coil for over 2 day i suspect it will last forever this way .....
emery and ed same same .....
i showed gk last year when i figuered this out ....  this infact is teslas secreat  ;) ;)
the verry cool part was this after my cap drained right out it was instantlly refilled  ;D  also ....   after some time i could not read it on my cheep meter i thought it had quit operation but in fact it had NOT!!!!   just cuz i could not read it did not mean it stoped
also i HAVE SCOPED THIS WAVE  i will garentee all of you it is a wave that has never been posted public as of yet ....
it is a verry mysterous wave ... a busy 1 .... ;D
i called it orbit i also at the same time when i scoped it i discovered how to speed it up and slow it down  ;D
how do i know i could control it ??   i watched it on my scope ...  oh  i placed a tuned coil above the rotating one  a tuned coil meaning a secondary tuned by length to 7.5 hz 131.2 ' there bouts 22 ga solid 4 " collector  no controls wound on it   did it pull form the source ??
of cource it did i had a ac voltage of 7.5 v  ;D
nope no vids schems or nuttin  reverse engineer this  :D ;D  :P
ist
what the hell is in my sig anyways??  whos words are those....  where did i find em and who the hell edited my sig .... lol .... hummm there is somthing missing in my sig ...  i know damn well i typed it word 4 word  ;D  the last sentence or 2 are missing why and what did they talk about ....   what pattend was it??
pauldude000
@Grumpy
You know an interesting effect? There was a time, when they were building what are now called "antique engines", or popularly "hit - and - miss". Interesting things with big flywheels. They had batteries, but at the time, they had a very simple means of firing the spark to ignite the gasoline. It was called a "kick" coil.
What was a "kick" coil? A simple solid iron core solenoid, with a single winding of many, many turns.
By itself, nothing but a waste of battery juice, a big magnet.
What was amazing is that when points were placed so as to make and break the connection, without a capacitor to drain the excess voltage off, this coil could attain 5000v or more upon breaking of the points, so a timing system was devised which would make the contact before the spark was needed, fully energize the coil, then the massive spike at break which would fire the plug.... We also see this at the strike of an arc in an arc welder.
Thousands of volts from a low voltage source has always been a current phenomena from a lower voltage source.
Now, "Kick" coils did not have to be an iron core solenoid. They could also be an air core solenoid, even at higher voltages.........
Electrons have both mass and inertia. Try to stop them or start them suddenly, and they react.
Why don't they still use them? Kick coils (at least the iron cored ones) get HOT after enough use.
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
innovation_station
in my 4 mot m tpu my mots work as kick coils .... 4 of em controlled many ways first a rotary switch 2nd reed switches and a magnetic wheel
they charge up caps i must short the cap on the out put to be of any use ...it should be fired then shorted right away this is for a lower voltage application other wise stick to over 1000v and it will self fire when the cap is full through a spark gap .... to the out put ....
ist
pauldude000
Mainly, I am trying to point out a simple fact to everyone. Terms which were common then, are not common now. Definitions which were applied then, are not necessarily the same now.
When asked to define his consideration of what was "high frequency" by his lawyer, Teslas reply was in the low/mid Khz range. Even 20 years later, this definition was outmoded, and is now ridiculous. Heck, our current band range in common use today is already outmoded in practice! (How is VHF, which is in the mid/high megahertz range, considered "Very High Frequency", when 2- 5 GIGA<--hertz is now in common use?)
Tesla designed what was commonly called a "death ray", which has a common definition today..... a particle accelerator. To say that what either Tesla OR SM was trying to say is "....", you HAVE to understand BOTH the lingo they were using, and try to understand what they were thinking. WHY they did this or that, to accomplish this or that goal.
Quit trying to place your or someone else's PERSONAL interpretation upon what they were saying, so that you can actually understand what they were saying!!!!!!!!!!!!! Accept that they were speaking the truth as they understood it, using the language they were accustomed to! Simple!
If I didn't know better, which I have to wonder sometimes if I do, I would say too much has changed into some form of a religion, rather than a science.
EVEN IF something new is discovered, which is entirely possible, then nothing "weird" has been discovered, but a new principle, or a new energy source, or a new "something". There is nothing "magical" or "mystical" about any of this. "NEW" things get examined, arranged, collated, and then filed in their proper place IN THE BOX! ;D
Keep the box in sight gentlemen! :D
( For the last statement, I HAD to say this whole post.... ;D Sorry, my weird sense of humor. )
Paul Andrulis
