The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
poynt99
Quote from: giantkiller on July 23, 2008, 06:15:11 PM
The kick is at the top of the bell curve edge hidden in the ringing. The next pulse in amplifies it. Unfortunately the DC part also causes its demise. The ringing in the DC part is the 2 forces fighting for control. The DC wins as shown by the stability of the voltage.
--giantkiller.
hey guys,
this from my super-ultra-infra-sonic-quadrature-heterodyning-phase-shifting-pre-emphasized-QAM-based-quantum-kick generator!
see the kick? it's right there! can't see it too well amongst all that noise, but it's there, i assure you ;)
:D LOL :D LOL :D LOL
Bruce_TPU
Quote from: poynt99 on July 23, 2008, 10:22:04 PM
hey guys,
Hey Troll,
Trying to mock a builder here is not cool.  (Bad Troll!!)
NOW, if you actually EVER built anything..... OH, never mind, that will never happen.  Time to crawl under your bridge, BEND OVER, and wait for the KICK!!!  IT will be there, i assure you ;)
Bruce_TPU
Double post, should have left it!  LOL
duff
With reference to the link EM posted to the SM video above
I set my function generator to 6000Hz. / 24Vpp output.
My multimeter read the following:
    Sin Wave:        0.106VDC
    Square Wave: 0.265VDC
Obviously SM has a strong DC component with the 6KHz ripple or a different wave form (yes, I know this has been discussed before)
@GK
What is the DC output of your Bell Curve Waveform (measured with a DVM),  the frequency of your pulses and duty cycle??
@poynt99
I would like to see your model and (raw) netfile.
@Bruce
A year ago or so, in your thread, I think you posted a link to someone doing work with the earth's magnetic field. I belive the guy was in Sweden or somewhere in that area. If I recall correctly he was visiting different geological locations, maybe his work took him there, anyway while he was there he was taking measurements and validating his work.
I've searched the thead but cannot find it. Maybe I'm not giving you enough specific info but that all I can recall.
If you have any idea who I'm referring to please post the link if you can find it.
Thanks
-Duff
Grumpy
Quote from: Bruce_TPU on July 23, 2008, 10:49:09 PM
Hey Troll,
Bruce,
These copper-tops are not worth the effort - probably MIB bot's anyway.   You can also tell the bot's because no matter what you say or show - it isn't enough and they ask for more.  Paul's "kicks" are just differentiated pulses - which if he knew how to apply them would be a good thing but he doesn't seem to know - otherwise they are just pulses and of no interest.
        -Frank Edwards
