The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
innovation_station
now were getting some where..... ;D ;D
good job forest
ist
now forest if you could discharge that to a primary of low selfinduction wound on the collector coil what would be the result?  out put out the secondary ?
and this would then be hot electricty or normal electricty the out put of the seccondary?
im intrested in hearing your results  8)
forest
Please, where can I find Spheric posts ? I don't understand those two pictures. They looks to me like Tesla experiments with displacement currents. If this is true that what I'm missing is the advantage of toroid core and rotating magnetic fields.
Hmm,it can't be so easy...
Open path vs closed path...  How would you enlarge displacement current and convert it back to ordinary hot current ?
Is open path and high frequency oscillation the key and magnetic fields and toroid core only an engineering choice to maintain it ? In other words : could we implement the simplest device first ?
Does someone has a knowledge if capacitors are used in TPU ?
innovation_station
i would tend to think that some translating device must be used  ;)
a cap a battery....
ist
forest
Quote from: innovation_station on July 26, 2008, 07:20:07 PM
good job forest
ist
first I have to learn how to wind collector coil, but I suspect that it will be hot electricity , because cap seems to convert it easily
however it may be too slow in case of my SSG (to low DC voltage)
Tesla used a coil with primary containing many turns of THIN INSULATED wire and a SECONDARY of coarse wire, but he described this experiment using quite contrary statements so amount of current or energy obtained in such a process is unknown. However if that amount is far greater then we expected .... ? Anyway he didn't explained where is this current accumulated and I bet it is in insulated plate. Bigger insulated plate connected to the coil terminal means bigger displacement current produced.
From Steven Mark texts I've always thought what he wanted to say by those words :
"Anyway, I have taken a high voltage power supply as follows:
500 v-0-500 v 300 mV plate transformer run it through a full wave silicon circuit then run it through a 5U4 electron tube rectifier.
Now you know that the 5U4 requires 5 volts AC at 3 amps for its heater to gather the electrons and complete the circuit.
Well, I measured the output from the tube and the result is 500 volts DC at 250 mV.
The loss is due to the high impedance of the tube and its limited ability to dissipate more than 250 mA..
The point I wish to make here is that also along with the 500 volt DC is, yes, you guessed it, the 5 volts three amp AC current!
They are both completely independent of each other except for some very interesting things I will mention to you some other time..
First of all, obviously you can have several different output components in the power output signal.
You can have DC and AC together without any problem"
Bruce_TPU
Quote from: forest on July 26, 2008, 07:36:57 PM
Hi Forest,
Here is the thread he started.  He only posted six times in it.  The first post is his, but you want the second post on page 2 or 3, can't remember.
http://www.overunity.com/index.php/topic,4297.msg83207.html#msg83207
Cheers,
Bruce
P.S.  I drew the pictures above.
