The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
poynt99
Quote from: Spider on July 26, 2008, 03:26:44 PM
Well Bruce,
Here is a simple experiment everybody can do.
It is about the infamous iron delay coils.
Tho you have to go into the nanoseconds to see it, its worth it. :)
greetings Spider
PS, I never said I would post anything usefull, I just wanted to show off my equipment LOL
hi spider.
what are we looking at there?
Grumpy
Quote from: poynt99 on July 26, 2008, 10:36:22 PM
hi spider.
iron delays the pulse - stretches it out - slows it down
        -Frank Edwards
poynt99
ok bruce, i'll ask for help about the spherics stuff.
in your drawing 1, where do you scope it? A-B, A+B, A AND B, A only, B only, which one?
in your drawing 2 you've used the spherics idea and configured it for the Steven Mark version i'm guessing. the kick coils, they are 3 separate coils with their own delay coils. ok, got that. are the 3 kick coils wound as toroidal coils sharing the same toroid form, or are they pointing toward the toroid from outside of it?
it looks to me like you are pointing the 3 control (kick) coils inward toward the toroid.
i'm open to these ideas, but 3 things don't equate to what SM told/showed us:
1. the collector is poloidal, yours/spherics is toroidal
2. the control coils are toroidal around the poloidal collector, your controls are separate solenoid coils pointing inward
3. SM calls for a frequency and 2 of its harmonics. spherics calls for 1 phase-shifted frequency.
appreciate any help on these points/questions.
pauldude000
@Loner
I just returned, and am now reading yours, and everyone else's replies.
As to wearing out your welcome. That would be difficult. You speak sense, and are asking highly relevant questions.
Personally, I think the effects (shown by spider) are duplicable through field manipulation using standard copper. It is starting to seem amazing to me what you can make a field do with nothing more than square waves (voltage limited pulses).
I am going to try your diode concept and see if I cannot integrate the pulses. If I succeed I will post the results. If not, I will let you know.
I also have some other ideas how this might be accomplished which I will experiment with. We'll see.
Time generally determines which concept of many is true.
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
sparks
   Tesla transformers use a mass equivalence relationship between the pulsed primary and the radiating secondary.  He also stored energy in his coils by use of series connected bifilar coils.  This increased both the number of turns and by series connecting caused a considerable increase in voltage between turns.  Squaring then doubling the energy stored in the coil by use of bifilar coils.
    Sm's solenoidal control windings appear to be designed so that a highfrequency pulse train is imposed on a bifilar wound solenoid coil which would be matched to optimise storage of the voltage.
     Perhaps the mass ratio of the control winding mass to the collector mass should be one to one.  And also an eye to the orientation of the solenoid to the earth mass.  (Electrical Density Information of the Earth has been said to flow at a 45 degree angle.  I am sure that it is different all over the globe and varys with altitude.)
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
